   / Share Pics of People Hauling or Towing Something Wrong #15,881
There are concrete blocks and cinder blocks. Cinder are weaker. The strength is turned the other direction.
True but neither have the tensile strength to be used as a vehicle support.
   / Share Pics of People Hauling or Towing Something Wrong #15,882
They make heavy weight blocks and light weight blocks. The light weight ones would support a bicycle but that’s about it. The heavy weight ones would probably support a vehicle but still not safe to do so. Also a concrete block doesn’t tolerate point loading at all. In a building they rest on level bed of mortar with flat lumber on top. Also a building has hundreds of blocks to carry the load. Putting a vehicle on 4 blocks is a way higher per block load.
   / Share Pics of People Hauling or Towing Something Wrong #15,883
Exactly. Cripple wall the way he has them. Not that I would use one in either direction when under a vehicle.
   / Share Pics of People Hauling or Towing Something Wrong #15,885
From Facebook...
   / Share Pics of People Hauling or Towing Something Wrong #15,886
Then there was the guy killed by working under a bus supported by jack stands that were too small...
A REMINDER: Jackstands, vehicle ramps, and other such devices that are customarily used in pairs are most often rated in pairs. The single unit has half the capacity of the pair.
Marketeers like to advertise bigger numbers. Consumers are often ignorant of such concepts as safety factor, the difference between breaking strength and working load limit, etc. and the consumers put themselves in peril. They also may be unaware of good practices (such as chocking a partially raised vehicle) and compound the problems, sometimes with fatal results.
   / Share Pics of People Hauling or Towing Something Wrong #15,889
   / Share Pics of People Hauling or Towing Something Wrong #15,890
Black Friday Special
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
JOHN DEERE 330G SKID LOADER (A58216)
JOHN DEERE 330G...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
2803 (A58376)
2803 (A58376)
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
