   / Share Pics of People Hauling or Towing Something Wrong #15,881
There are concrete blocks and cinder blocks. Cinder are weaker. The strength is turned the other direction.
True but neither have the tensile strength to be used as a vehicle support.
   / Share Pics of People Hauling or Towing Something Wrong #15,882
They make heavy weight blocks and light weight blocks. The light weight ones would support a bicycle but that’s about it. The heavy weight ones would probably support a vehicle but still not safe to do so. Also a concrete block doesn’t tolerate point loading at all. In a building they rest on level bed of mortar with flat lumber on top. Also a building has hundreds of blocks to carry the load. Putting a vehicle on 4 blocks is a way higher per block load.
   / Share Pics of People Hauling or Towing Something Wrong #15,883
Exactly. Cripple wall the way he has them. Not that I would use one in either direction when under a vehicle.
   / Share Pics of People Hauling or Towing Something Wrong #15,885
From Facebook...
   / Share Pics of People Hauling or Towing Something Wrong #15,886
Then there was the guy killed by working under a bus supported by jack stands that were too small...
A REMINDER: Jackstands, vehicle ramps, and other such devices that are customarily used in pairs are most often rated in pairs. The single unit has half the capacity of the pair.
Marketeers like to advertise bigger numbers. Consumers are often ignorant of such concepts as safety factor, the difference between breaking strength and working load limit, etc. and the consumers put themselves in peril. They also may be unaware of good practices (such as chocking a partially raised vehicle) and compound the problems, sometimes with fatal results.
   / Share Pics of People Hauling or Towing Something Wrong #15,889
   / Share Pics of People Hauling or Towing Something Wrong #15,890
Black Friday Special
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
LOAD OUT AND SHIPPING (A57454)
LOAD OUT AND...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2008 Ford F-250...
TOWNSEND BOP (A58216)
2019 GALYEAN...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
