   / Share Pics of People Hauling or Towing Something Wrong #15,871
I saw this genius on Facebook.
   / Share Pics of People Hauling or Towing Something Wrong #15,873
   / Share Pics of People Hauling or Towing Something Wrong #15,874
You can fragment those blocks swinging one in each hand. Slam them together. Boom. BTDT.
   / Share Pics of People Hauling or Towing Something Wrong #15,878
Years ago the son of one of my parent's employees was killed when a cinder block failed while he was under a car.
I went past my neighbor's house and noticed he was under his car, which was supported by cinder blocks. I turned around and returned home, cut a couple chunks of hemlock off a tree I'd just felled and brought them to him. "Thanks" he said. "But if they will support a mobile home they will hold up a car."
Even the hemlock isn't perfect, I believe that a TBN member was killed when an implement fell on him after the wood supporting it split.
   / Share Pics of People Hauling or Towing Something Wrong #15,880
There are concrete blocks and cinder blocks. Cinder are weaker. The strength is turned the other direction.
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
CFG Industry QK16R Mini Excavator (A57149)
CFG Industry QK16R...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
