   / Share Pics of People Hauling or Towing Something Wrong #15,871
I saw this genius on Facebook.
   / Share Pics of People Hauling or Towing Something Wrong #15,873
   / Share Pics of People Hauling or Towing Something Wrong #15,874
You can fragment those blocks swinging one in each hand. Slam them together. Boom. BTDT.
   / Share Pics of People Hauling or Towing Something Wrong #15,878
Years ago the son of one of my parent's employees was killed when a cinder block failed while he was under a car.
I went past my neighbor's house and noticed he was under his car, which was supported by cinder blocks. I turned around and returned home, cut a couple chunks of hemlock off a tree I'd just felled and brought them to him. "Thanks" he said. "But if they will support a mobile home they will hold up a car."
Even the hemlock isn't perfect, I believe that a TBN member was killed when an implement fell on him after the wood supporting it split.
   / Share Pics of People Hauling or Towing Something Wrong #15,880
There are concrete blocks and cinder blocks. Cinder are weaker. The strength is turned the other direction.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
4000 Gallon Fuel Tank (A50775)
4000 Gallon Fuel...
CFG Industrial XZ20R (A53316)
CFG Industrial...
40' High Cube-Multi Door Container (A53316)
40' High...
202473 (A54757)
202473 (A54757)
