Seventh Project ( Chain Tray)
/ Seventh Project ( Chain Tray) #11
Why not use 4" pipe? You could glue a cap on one end and use a female adapter and a plug on the other?
/ Seventh Project ( Chain Tray) #12
Steven,
I suspect the reason Jan made a drawer is that his opening is too small to push a chain directly in. But with your 5.5 ID , couldn't you just eliminate the drawer and figure out a way to cap the ends?
John
/ Seventh Project ( Chain Tray) #13
That's a NEAT idea. I too have a round tube, but I suppose a guy could use a PVC as mentioned previously. The top load is a neat idea.
A guy could leave it full round at each end for a bit and scoop out the top using a chunk of the top screwed in place as a drawer stop....
Need to keep it breathable/well drained in case it is put away wet.
/ Seventh Project ( Chain Tray) #14
KennedyDiesel good point there are many times when the chain could be damp what a mess that would be when you opened it up a week or so later one big pile of rust. I'm going on the hunt tommorrow for a way to use that tube because as I'm sure many people will laugh this 30' of 1/2" chain I opt'd for is heavy and the only place I've found to put it is in the bucket if it were mounted but most the time I have the grapple on and then I have to wrap it around it to carry or ride with it under my feet.
Steve
Steven:
I went with the tray idea because chain doesn't push well /forums/images/graemlins/wink.gif
I pull the drawer almost all the way out and just lay the chain in
back and forth until it is all in, takes about 4 seconds. shut the drawer and lock and your on your way.
I don't know of any PVC with a 5 inch dia. outside of ordering it from a plastic co. They have about any size your willing to pay for, but you could cut out a slot in some 5" thin wall tubing and make it work. good luck!
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A60352)
2022...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
1997 Wilson Pacesetter 8'x42' Hopper Bottom (A60462)
1997 Wilson...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2014 FORD F-150 (A60736)
2014 FORD F-150...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
