service gator
/ service gator #1
miichelle linnane
I just finished draining the transmission fluid out of the gator, but I do not know where the oil drain plug is? I got all the stuff to service gator with but have not found the oil drain plug?
Michelle Linnane
/ service gator #3
What kind of a gator is it? 6x4 4x2 4x4?
/ service gator #4
Yes, after about 13 hours or so, I removed my spark arrestor for good. That thing was starting to clog up . I instantly, I could tell the difference in the way the RTV performed when it was removed. It could get rid of that hot air alot quicker without forming all that back-pressure >>>>>>.
Some folks might need it were they run there RTV, ( goverment owned propery ) but here, I OWN THIS LAND >>> AND CAN RUN ANYTHING ON IT I WANT !!!!!
NO WAY WILL IT EVER GO BACK ON !!!! Don't know why they put one on a diesel anyway !
/ service gator #5
I have a 4x2 gator and I took mine off today. I can tell a difference.
/ service gator #6
cat2,
I took mine off the Honda Rubicons a few months ago. Removing the one off the Kubota RTV, made me think of the four-wheelers, so the same day, they came off also . And WOW, talking about performance, it was the difference between night & day .... even with the gas burners. All that back pressure sure holds back a engine.:cool:
/ service gator #7
Yeah my diesel HPX seemed to get slower a month or so after I got it. I took off the spark arrestor and it was completely clogged, all of my speed came back with it off.
/ service gator #8
I have an 07 XUV, how does does the spark arrestor come off? I see no need for it.
/ service gator #9
On mine you just take one little screw out. And pull it off. Mine didn't want to come off. Had to go on the back of it with a hammer and chesil to get it started then take a pair of vis grips to rip it off. It sure does help
/ service gator #10
i recntly took my exhaust off when i did my clutch belt and i flushed out it out and man was it all sooted up i too have been running with the arrestor out for a while now but the pipes are or should i say was getting sooted up too.i wanna clean out the exhaust ports next they was dirty too i did them as best i could but it was that good of a job.i have about 540 or 550 hour on it i think.
/ service gator #11
Michelle,
Your other post says it is a 6x4 but didn't say if it is a gas or diesel. If gas, standing on the left side there is a drain valve towards the bottom on the side of the engine. The valve should have a plastic tube on it that you stick through a hole in the belly pan to drain. Loosen (don't try to remove) the drain valve with a 10mm wrench. Hope that helps.
dsb
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
4 Shelf Rolling...
New/Unused Pallet of 5 Binders and 10 Chains (A61166)
New/Unused Pallet...
207271 (A52708)
207271 (A52708)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
