service gator
/ service gator #1
miichelle linnane
I just finished draining the transmission fluid out of the gator, but I do not know where the oil drain plug is? I got all the stuff to service gator with but have not found the oil drain plug?
Michelle Linnane
/ service gator #3
What kind of a gator is it? 6x4 4x2 4x4?
/ service gator #4
Yes, after about 13 hours or so, I removed my spark arrestor for good. That thing was starting to clog up . I instantly, I could tell the difference in the way the RTV performed when it was removed. It could get rid of that hot air alot quicker without forming all that back-pressure >>>>>>.
Some folks might need it were they run there RTV, ( goverment owned propery ) but here, I OWN THIS LAND >>> AND CAN RUN ANYTHING ON IT I WANT !!!!!
NO WAY WILL IT EVER GO BACK ON !!!! Don't know why they put one on a diesel anyway !
/ service gator #6
cat2,
I took mine off the Honda Rubicons a few months ago. Removing the one off the Kubota RTV, made me think of the four-wheelers, so the same day, they came off also . And WOW, talking about performance, it was the difference between night & day .... even with the gas burners. All that back pressure sure holds back a engine.:cool:
/ service gator #7
Yeah my diesel HPX seemed to get slower a month or so after I got it. I took off the spark arrestor and it was completely clogged, all of my speed came back with it off.
/ service gator #8
I have an 07 XUV, how does does the spark arrestor come off? I see no need for it.
/ service gator #9
On mine you just take one little screw out. And pull it off. Mine didn't want to come off. Had to go on the back of it with a hammer and chesil to get it started then take a pair of vis grips to rip it off. It sure does help
/ service gator #10
i recntly took my exhaust off when i did my clutch belt and i flushed out it out and man was it all sooted up i too have been running with the arrestor out for a while now but the pipes are or should i say was getting sooted up too.i wanna clean out the exhaust ports next they was dirty too i did them as best i could but it was that good of a job.i have about 540 or 550 hour on it i think.
/ service gator #11
Michelle,
Your other post says it is a 6x4 but didn't say if it is a gas or diesel. If gas, standing on the left side there is a drain valve towards the bottom on the side of the engine. The valve should have a plastic tube on it that you stick through a hole in the belly pan to drain. Loosen (don't try to remove) the drain valve with a 10mm wrench. Hope that helps.
dsb
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A68183)
2001 Freightliner...
2016 Ford F-750 (A64911)
2016 Ford F-750...
Unused 2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
Unused 2023 USA...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
Unused HLA BRB84 84in. Hydraulic Rotary Pick-UP Broom Skid Steer Attachment (A66734)
Unused HLA BRB84...
