service gator
   / service gator #1
miichelle linnane
I just finished draining the transmission fluid out of the gator, but I do not know where the oil drain plug is? I got all the stuff to service gator with but have not found the oil drain plug?
Michelle Linnane
   / service gator #3
What kind of a gator is it? 6x4 4x2 4x4?
   / service gator #4
Yes, after about 13 hours or so, I removed my spark arrestor for good. That thing was starting to clog up . I instantly, I could tell the difference in the way the RTV performed when it was removed. It could get rid of that hot air alot quicker without forming all that back-pressure >>>>>>.
Some folks might need it were they run there RTV, ( goverment owned propery ) but here, I OWN THIS LAND >>> AND CAN RUN ANYTHING ON IT I WANT !!!!!
NO WAY WILL IT EVER GO BACK ON !!!! Don't know why they put one on a diesel anyway !
   / service gator #5
I have a 4x2 gator and I took mine off today. I can tell a difference.
   / service gator #6
cat2,
I took mine off the Honda Rubicons a few months ago. Removing the one off the Kubota RTV, made me think of the four-wheelers, so the same day, they came off also . And WOW, talking about performance, it was the difference between night & day .... even with the gas burners. All that back pressure sure holds back a engine.:cool:
   / service gator #7
Yeah my diesel HPX seemed to get slower a month or so after I got it. I took off the spark arrestor and it was completely clogged, all of my speed came back with it off.
   / service gator #8
I have an 07 XUV, how does does the spark arrestor come off? I see no need for it.
   / service gator #9
On mine you just take one little screw out. And pull it off. Mine didn't want to come off. Had to go on the back of it with a hammer and chesil to get it started then take a pair of vis grips to rip it off. It sure does help
   / service gator #10
i recntly took my exhaust off when i did my clutch belt and i flushed out it out and man was it all sooted up i too have been running with the arrestor out for a while now but the pipes are or should i say was getting sooted up too.i wanna clean out the exhaust ports next they was dirty too i did them as best i could but it was that good of a job.i have about 540 or 550 hour on it i think.
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
