service gator
/ service gator #11
Michelle,
Your other post says it is a 6x4 but didn't say if it is a gas or diesel. If gas, standing on the left side there is a drain valve towards the bottom on the side of the engine. The valve should have a plastic tube on it that you stick through a hole in the belly pan to drain. Loosen (don't try to remove) the drain valve with a 10mm wrench. Hope that helps.
dsb
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
207271 (A52708)
207271 (A52708)
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
Mufflers for vacuum pump system (5 units) (A60736)
Mufflers for...
Attention (A57148)
Attention (A57148)
