septic
/ septic #1
schmism
Super Member
Peoria IL
New holland TC(33)
so we are in the process of biding our septic (new) for our new apt/house on the property.
got the soils test back today
seasonal high water table is 18" (yes thats inches not feet)
NOW WHAT!
toward the back of my property it starts to fall off a BIT... (im talking 5-6' tops) so im hopeing the water table would drop off back toward the back but that means a) more tests. and b) the locaion isnt going to be cental to the buildings meaning id likely have to put in 2 complete systems (one for the apt one for the big house in a few years) which we were trying to avoid.
<sigh> nothing is ever simple
/ septic #2
That's pretty common in this neck of the woods. As a result I've got two aerobic septic systems on my place. While I really don't like having to power the blowers and pumps all the time, they really aren't that bad. I put liquid clorinators on both of them, that eleminates a lot of hassle.
/ septic #3
You're lucky to have 18". I've seen mound systems used in as little as 6" of dry ground above the water table. An all gravity system would be very nice but very often it is just not possible.
/ septic #4
Have you looked at the Eco Flow or Pure flow peat moss systems? You can use an above ground absorbtion mound about 18" high. Also, a Delta clearwater aerobic unit with low pressure distribution absorbtion system. All of these use a pump disposal system that will allow the tank where you want it and then pump to the absorbtion pad. Are you using the public health dept to design this or a private designer. One thing to watch out for with a private guy is most time they will only specify the products they make a commision on.
/ septic
so i guess its not impossible
the septic guy gave me abid of $4500 with 300+ ft of latterls.
so at .5% fall (6" over 100') i can set my tank at "ground level" loose 6" for my run. and wind up with a foot to of cover over the drain feild. (water table ranges from 18-24") so....
i think we will be able to get something to work.
not as deep as i wanted but it should stilll work.
/ septic #7
Bones, it's true though...at leats with my wife.
schmism, In VA 18" is a "no go" for convetional system - you are getting a good deal at that price. In VA. Aerobic units start at 10k, peatmoss at 14k and my neighbor just put one in for 18k. Also you have to pay the engineer 2k for the certified plans regardless of which system.
/ septic #8
Good gosh they're proud of septic systems in Virginia. My aerobic systems with 1,000 gal tanks cost $4,500 each, installed. The engineer charged me $350 for the site/soil analysis and certified design, and the county charged me $160.00 for the permit......And I was complaining about being robbed.
/ septic
when i started this project i sat down with a pencile and paper and wrote down most of the major catagoies for constrution for the project and put a dollar mount next to each. kinda of a pull-a-number-out-of-the-air with my limited experience. (get an idea of the cost for the project)
the number i wrote down for septic was $5000 so it was right on target.
my jaw bout hit the ground when the soils guy said he would bore test (with seasonal high water table) for $175. (my thought was a DEAL at $300) Even more surprised when i called him and he said he was slow and could be out THE NEXT DAY to do it!!! :eek:
hopefully this is a sign of other things to come :D
septic permit is $200 with a (non inforced just for tax records) building permit required to be pulled at the same time for an addtional $100.
/ septic #11
That is cheep for a system here in Pa. they are using a lot of what is called sand mound I put in three this year for customers and the cheepest was real close to $10,000.00 the biggest was over $16,000.00 with the tanks pump and mound
/ septic
ya they were trying to "sell" me a sand mound/pit whatever ... to me it sounded like a lot less work for a lot more money... (no wonder they like to put them in)
/ septic #13
Wisconsin Sand Mound. Dr. Gerry Tyler's invention . Best thing since Wisconsin cheese. Usually used where there is a shale layer or other limiting factor near the surface. We don't use them much East of the Blue Ridge and that is a good thing.
/ septic #14
Tell me more about that...and some other alternatives to conventional systems. We have a cottage across the road from our meadow that we rent out. The 50 year old septic system has completely failed: the pipe from the cottage is partially crushed, the 400 gallon metal tank is completely rusted thru, and since the baffles went first the grease the tenants dumped down the sink has ruined the leach field.
The only spot with decent depth is right where the old tank is. Five feet downhill there is just a couple of feet of dirt over granite ledge, which is where the original 20 foot long leach field was located. Since I only have about 20 feet where a tank can be buried, my engineer wants to place the leach field in the meadow across the road. That means a couple of expensive issues need to be addressed.
1. There is granite ledge between the cottage and where the new field will be, so blasting is involved.
2. The new field will be slightly uphill from the drain, so a pump will be needed.
3. The pipe from house to field will pass under our dirt driveway, which is also the route I take when bringing heavy loads of hay to the barn, so the run has to be very deep.
4. If we ever sell the property the buyer has to be willing to accept having a leach field up there, and directly downhill about a hundred yards is our pond, which I don't want fouled with coliform.
It sure would be nice to keep the crap on the other side of the road. So we've been looking at some of those treatment systems that use pumps to aerate the mix. Are they any good? Are they reliable?
Pete
/ septic #15
Quote here in Johnson County for a sand mound ranges from $20k - $25k...........and that's the only kind the county will approve.........:(
/ septic #16
Hey Boondox,
I thought you had your own backhoe (wink).
jb
/ septic #17
Boondox, I'd review your state's septic regs to see what systems are approved in your area. Manufactures may have some of their units approved in your state and some not. The aeration units you speak of are probably Areobic Treatment units which use a turbine blower to aerate the mix. No moving parts other than the blower. ATU's will produce waste water as clean as storm water so their might be an option for spray irrigation if you have a secluded area. Take a look at the Biomicrobics website, they have a Microfast unit which is a ATU that fits inside a conventional concrete septic tank. If you can go the drain field route this will allow the drain field to be gravity fed eliminating the pump. Pumps are a big deal in VA because they require a 900 gal chamber in addition to the pump and controls so they add about 4k to the cost. Lots of expensive options at this point. The biggest thing to realize is that the engineer may not have your best interest at hand. In VA the designers actually receive a sales commission for specifying a mfg. product. PM if I can help.
/ septic #18
NOW WHAT!
Bummer.
I live on the valley floor here in the North Sacramento Valley. Lotsa clay. I had to have three trenches dug (3'W x 10'D) before we hit gravely loam in the backyard area here on my 10-acre spread. Lucked out. The health inspector asked me how many bedrooms. I said three. He said 1250 gal tank and 100 ft of leach line buried 4-ft deep over 2-ft thickness of drain rock. Total cost: $3500 for the system installed and $250 for the permit.
I was lucky to have an area that perked well with water table well below the surface. Otherwise I would have had to get good perking soil trucked in. Cost probably would have been $10-15K.
/ septic #19
john_bud said:
Hey Boondox,
jb
JB -- I got rid of it when I traded up from the L3010 to the L4630, intending to get a 9 footer. But then a friend let me borrow his mini excavator and it completely ruined backhoes for me! If I can put an aerator unit on the same side of the road as the cottage, it would be a powerful argument for getting the excavator this year. If it can't fit on the same side of the road I'm out of luck because the only way to run the septic over there is to blast thru the ledge. Don't need the excavator for that!
Shaley -- Good advice. I'll check with the town tomorrow morning. Thanks!
2017 Isuzu NPR-HD 14ft. Stakebody Flatbed Truck (A64556)
2017 Isuzu NPR-HD...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
2011 WESTERN STAR 4900SA (INOPERABLE) (A65643)
2011 WESTERN STAR...
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
