Septic Smells
/ Septic Smells #51
Ok, so, pumping, I'll give you what I see; the septic contractors that run a pump service will recommend having a system pumped every 1-5 years, the septic contractors that just do new installs and/or repairs (and the pumping required for repairs) general don't locally recommend pumping. A functional system should last many many years. Honestly, if your needing to pump every year or every 2-3, either you are paranoid, or have a problem. Tons of folks go 20-30+ years having never pumped.
Now, to the smell; can you visually see the access or is it buried? You say "lid" which to me, is the top slab on a concrete tank, but the majority of tanks are poly or fiberglass now, although concrete is still used. If we mean the actual access (often there are two), is visible, clean around it, and see if that is where the smell is coming. A septic tank, by vary definition should be without air, totally different bugs than a aerobic system like a sewer plant.
Being used so little, it is possible that is the source of the problem, but I'm guessing it's more likely the "lid". You still want to maintain access for future, but you could seal the outside with a tar/bituminous product. It won't be "easy" to open, but it still can be.
As far as checking if it needs pumped, and if we are able to see the actual access, you can open it, and take a pipe or stick and get an idea of how much solids have built up. The tank will be full, but we should have oils on top (thin layer, shouldnt be a lot), water, and the very bottom will be sludge and solids. I Highly doubt, that after just a few years, of seasonal usage, the sludge/solids are needing pumped.
I wire in septic pump motors for 3 contractors…new construction only….and all 3 recommend pumping every 5 years as a minimum. They have all told me of having to establish new drain fields for people that dont pump their systems. And none like to deal with old, used systems. They beg their clients to pump them.
And their not in the pumping business.
I dont care how the system is set up, they all get sludge built up.
/ Septic Smells #52
Is there a dead cat under the porch??
How about a mouse in the gutter??
These could smell very similar,, and have nothing to do with the septic,,,
/ Septic Smells
Three things I advise not to feed esp into an 'undersized' septic are:
1) Kitchen grinder. Too much organic material to digest.
2) Dishwasher. No-touch cleaning agents are strong and kill off both aerobic and anaerobic bacteria.
3) Clothes washer. It's gray water, not sewage. Detergents and o'all volume can be a bit much there too and push yuk into the field.
Bought my last house in '89 and it hadn't had the tank pumped in quite a while because a rip-rap patio partially covered it. Moved out in '01 and sold it it '07 to a family of five. Resold twice and only the last owner had the system pumped, then the field replaced. Big families several kids, sink grinder, and lots of washing. We are on well perked sand and don't see greener grass above our lines
Moved here in '01 1/2 mi down the road (uphill btw) and haven't been pumped yet. No dishwasher or grinder, and laundry has its own discharge. House in front of me has 500 gal tank has been pumped several times. 10 yrs ago we replaced all lines and added T-baffles to inlet and outlet. (not even there before) things settled down after I got them to ditch the DW and send laundry water out into the yard vs into the septic. Made 'em a dry well for wash water and all is well.
My philosophy in all maters is that if more than one cause is possible it's never just one that creates a problem.
2 of the 3 we don't have - no grabage disposal, and we don't put coffee grounds, grease, or anything else in drains. and no dishwasher. We do have a washer which we occasionally run (every 3 or 4 months) usually 1 load....Thanks for your reply.
Edit: I did notice the odor last time there when I ran a lot of water to give my dog a thorough bath. The odor was as bad as I remember after that. Maybe overwhelmed the system?
I plan to lift the lid, check the sludge depth, and look for cracks, airtight or loose connections next time down.
/ Septic Smells #55
Smoke bomb in a 16 gallon vaccum and blown into roof vent... with drains in cabin covered. Hope it works!
I haven't ever done this, but I have to ask; have you ever done this before?
Are you planning on capping all of the roof vents? (Generally, one per sink, shower, washing machine...)
It just seems like a big flow mismatch between a capped drain system and a vacuum. I'm also visualizing lots of spray and burps out of the various traps and drains in the cottage.
It's your nickel, but this sounds like a great recipe for a must watch YouTube video...
All the best,
Peter
/ Septic Smells #56
So, IMO, this is 100% not a pumping issue; if the tank can't take a couple years of minimum use... the bugs will eat the "solids" and sure, slug will build up, but no more than your use, it would be well less than 1" per year.
/ Septic Smells
All the best,
Peter
Never done it either, but I'm not a quitter!!!lol
There's only 1 roof vent. There are 2 sinks, 1 stool, a floor drain, a bathtub drain, and a washer drain.......what could go wrong? lol
/ Septic Smells #58
Has he ever looked to see how much sludge is in the tank? Our tanks must be pumped if the sludge level is at the 1/3 capacity of the tank. I have a feeling that he is treating it as "out of sight, out of mind" and will call when there are issues. Then it is too late. Florida does many things different but we value our ground water quality here.
We could not even find the tank so its been at least 20 years now
/ Septic Smells #59
We are 30 on ours. What I've always been told, don't mess with it, pumping can cause as much trouble as it fixes. Now, of coarse, this changes if your flushing non digestible materials, "rags", cotton wipes, "rubber products" ect. Also, I am fully aware that by the time you notice a problem, it's probably time to replace the drain field.
/ Septic Smells #60
They need to be pumped but the time varies. There are also lots of different systems, some modern, some not. Ours dumps out on the ground and it’s suppose to and meets code. It’s a Multiflo units and is aerobic with a filter system. The bad of that type of unit is it uses electricity, maybe $200 a year.
Box of Transport Ratchet Straps (A59230)
Box of Transport...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
