bigtiller
Super Member
- Joined
- Feb 1, 2006
- Messages
- 7,499
- Location
- central Iowa
- Tractor
- John Deere 2720 John Deere 3039R John Deere Z545R
I would call a "septic repair & maintenance" company near you. They know their "stuff."
How 'bout posting a pic of the system and this "open air outlet pipe"?the outlet pipe which is open air dumped about 100' away, the cleanout, or the lid not being airtight.
OK, not being a plumber, or educated in septic systems, I may have mistakenly mischaracterized the discharge of waste water from the outlet. I just assumed it ran out the end of the pipe from the tank into the open air. Sounds like that is an unlikely setup. I've never smelled anything near where I think the outlet pipe is run to. (it's very likely in a tall grassy, kinda brushy area that is hard to investigate). Regardless, I don't think it comes from the outlet pipe as a potential source of the smell...How 'bout posting a pic of the system and this "open air outlet pipe"?
And to repeat, there is no inside smell, just outside near the tank.
Edited to add: I put yeast in about every month, and we don't use bleach, as it's mostly used as a hunting shack.
Interesting....does the 300 gal tank collect the solids and the liquid runs out a pipe instead of a septic field?OK, not being a plumber, or educated in septic systems, I may have mistakenly mischaracterized the discharge of waste water from the outlet. I just assumed it ran out the end of the pipe from the tank into the open air. Sounds like that is an unlikely setup. I've never smelled anything near where I think the outlet pipe is run to. (it's very likely in a tall grassy, kinda brushy area that is hard to investigate). Regardless, I don't think it comes from the outlet pipe as a potential source of the smell...
Has he ever looked to see how much sludge is in the tank? Our tanks must be pumped if the sludge level is at the 1/3 capacity of the tank. I have a feeling that he is treating it as "out of sight, out of mind" and will call when there are issues. Then it is too late. Florida does many things different but we value our ground water quality here.My farther in law down in Florida has never ever pumped his septic out. My guess is the hotter it is the cycle never gets interrupted by cold.
Haven't read the rest of the posts below this post, but many folks are telling me something similar - that it shouldn't need pumped for a long time if ever. The plastic lid is plainly visible (at least 1 lid, not sure if there are more). I've moved the dirt and rock where the lid attaches to the tank or riser, not sure what's there, and that's where I see a wave where the lid comes up a 1/4" from the - let's call it the tank. It's still really hard to tell if that's where the odor is coming from tho, as the smell comes and goes...... I plan to take the lid off next time I'm there and see what i can see. I also plan to do a smoke test by pumping smoke down the roof vent and see if smoke comes out the cleanout, the lid, or ground somewhere. That's my plan at this point. Then I can call my plumber but he seems like he's wanting to just dig it up and hasn't even seen it yet. Plumbers are hard to find in the area before someone says "just find another plumber".....Ok, so, pumping, I'll give you what I see; the septic contractors that run a pump service will recommend having a system pumped every 1-5 years, the septic contractors that just do new installs and/or repairs (and the pumping required for repairs) general don't locally recommend pumping. A functional system should last many many years. Honestly, if your needing to pump every year or every 2-3, either you are paranoid, or have a problem. Tons of folks go 20-30+ years having never pumped.
Now, to the smell; can you visually see the access or is it buried? You say "lid" which to me, is the top slab on a concrete tank, but the majority of tanks are poly or fiberglass now, although concrete is still used. If we mean the actual access (often there are two), is visible, clean around it, and see if that is where the smell is coming. A septic tank, by vary definition should be without air, totally different bugs than a aerobic system like a sewer plant.
Being used so little, it is possible that is the source of the problem, but I'm guessing it's more likely the "lid". You still want to maintain access for future, but you could seal the outside with a tar/bituminous product. It won't be "easy" to open, but it still can be.
As far as checking if it needs pumped, and if we are able to see the actual access, you can open it, and take a pipe or stick and get an idea of how much solids have built up. The tank will be full, but we should have oils on top (thin layer, shouldnt be a lot), water, and the very bottom will be sludge and solids. I Highly doubt, that after just a few years, of seasonal usage, the sludge/solids are needing pumped.
