Semi-permanent 3pth bushing?
/ Semi-permanent 3pth bushing? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
My tractor has great extendable 3pt lift arms and a nice top link. Problem is that they are cat 2 and every implement I own is cat 1.
I really dislike using reduction bushings! They are fiddley and easily lost and worse yet can work themselves half way out of the link with some of my implements under use.
I replaced the top link with an old cat1 I had laying arroud but it was to short any would have just been a partial solution.
Has anyone tried semi-permanently afixing the reduction bushings in the 3pth?
I was thinking, after cleaning, a carefully applied thin coating of silicone calk might hold them in place. If, in the unlikely event I need cat2 pins, I could pound the bushins out.
Another option might be a couple of tack welds.
Any thoughts would be appreciated!
/ Semi-permanent 3pth bushing? #2
Tack weld and you will know where the bushings are. Simple grinder to remove if you ever need to. Tractor supply stocks a longer top link in the cat 1. That should solve the problem.
/ Semi-permanent 3pth bushing? #3
Just update the equipment pins to category 2
/ Semi-permanent 3pth bushing? #5
/ Semi-permanent 3pth bushing? #6
How about buying a category one quick-hitch?
/ Semi-permanent 3pth bushing? #7
I dont see how you are loosing the bushings. When the implement is hooked up, they cannot go anywhere. When you unhook, throw them in the tractor toolbox ready for next use.
Thanks for the tip. ��
Too many implements. Those pins aren't free.
Duplex balls! Never seen those. (not that im an expert on balls!)
Would you use a press to remove and reinstall the balls? Has anyone every done this?
/ Semi-permanent 3pth bushing? #11
The Quick Hitch is the way to go. I have two= 1 in Cat 1 and 1 in Cat 2. I have all bases covered.
/ Semi-permanent 3pth bushing? #12
Locktite high strength retaining compound. P/N 638.
Oh! Now this is why I posted this! Excellent ide spyder. Think I'd ever be able to get them out if i had too?
/ Semi-permanent 3pth bushing? #14
before you decide to jump on a QH, make sure your implements are QH compatible
/ Semi-permanent 3pth bushing? #15
Yes. Loctite 638 is right up there with the strongest, but weakens readily when hot ... something like 50% at 250F.
Give it time to cure well before use. Some heat helps - up to 200F late in the cure. A couple days in the hot summer sun and an incandescent light close on it at nite should give near full strength.
,,,larry
But I want to be able to pound it out if needed.
/ Semi-permanent 3pth bushing? #17
... Pull it into a deep socket with a bolt. - Much more graceful.
/ Semi-permanent 3pth bushing? #18
My Ford has interchangeable balls. CAT I or CAT II. Changing them doesn't even involve a tool. All done by hand.
Beyond that.
Don't weld or "glue" bushings to your tractor. If you are determined to fasten bushings in place, but a pair for each implement and tack weld them to the implement.
You thus don't do damage to your tractor. And you can easily remove the bushings from the implements if needed.
Beyond that.
Another reason I don't like the bushings is that, even with the longer bushings, they can work themselves halfway out. Not good for even wear and distribution of weight/stress. Putting bushings on the implements won't fix that. Hmmm....
/ Semi-permanent 3pth bushing? #20
Then for you the solution might be to attach them to your tractor's 3pt arms. For the same reason you mention above, it's going to take a pretty strong adhesive to keep them in place. Probably require tack welding. Just keep in mind you might want to reverse that decision.
