selector valve
/ selector valve #61
Have you got to use the valve yet. I have been waiting to buy one. I wanted to make sure it would do every thing we thought it woud before buying.
Bill
/ selector valve #62
Generally I don't think it is a good idea to pick and hold these coils. That said my front selector for a thumb on the bucket was a kit from Fasse and it had two switches on the grip one momentary and the other a toggle. The toggle allowed hold . But I still would not do it.
Right! A lock valve for 80 bucks will hold the cylinder in place with no need to energize the solenoid.
jb
/ selector valve #63
Bill
I have not run it yet , another week or two. I did attach the Cat maintainence pages a few posts back and some one else did run it.
/ selector valve #64
In my experience, coils on solenoids can certainly be kept energized, but I don't know if there is anything special about these coils.
Basically if they don't over-heat, you should be fine.
I have a safety coil on a liquid nitrogen line that has been energized for years. Of course it is not in much risk of over-heating. :)
/ selector valve #65
Great looking mods guys!
sunset, I was thinking you might use that "handle dip" that is generally for pliers and the like, it is a rubbery plastic stuff. Do you know what I'm talking about? I was thinking you could dip/brush it on your handle, should weatherproof the whole works.
ArTrvlr I love the looks of your handle. I'm going to have to do something like that.
I'm thinking of getting this same valve for the addition of a grapple and I really think that is the way I'm going to go.
Thanks to Hooked on HP for showing me this thread.
Patrick
/ selector valve #66
Well, I finally got a chance to paint the bondo knob and finish the switch mounting plate. Also the switch came in. Yea, I made the switch recess in the knob and the hole in the mounting plate without having a switch on hand for measurements. But the switch supplier (delcity.net) had good dimensions on it's website and in their catalog. I went by the dimensions and hoped for the best. This is the DPDT rocker switch I used: Del City Item 7500011
This is the drawing with all the dimensions and circuit diagram: http://www.delcity.net/images/linedrawings/7500011.pdf
First pics are of the switch and the switch plate. The terminal on the center lug in the first pic is a "flag" type, also from Del City. Part No. 192175. I am using them because of the limited depth of the hole in the knob. The wires will come off the side instead of the bottom like with regular terminals.
This is the finished knob:
The bolts sticking out of the shaft at the base of the knob will be replaced with setscrews. The next one compares it to the original shift knob I copied. It turned out a little "fatter" than the original but that doesn't seem to matter, as you can see above, my thumb lands on the rocker switch just right. I used Rust-Oleum orange and it's a pretty good match.
Next I need to mount the valve on the FEL and do all the plumbing and wiring.
jp
/ selector valve #67
Your handle turned out nice. I have used bond for a lot of things it wasn't intended for but never thought of using it to mold a shape. I ordered my valve and fittings and hopefully it will come in this week and I can get started on the plumbing. Did you make the plate for your switch or buy it
Bill
/ selector valve #68
Bill
Thanks. It wasn't hard to make, but not sure I would recommend it for a first time bondo project. I have been smearing that stuff since I was a kid. I really think it is important to use a fiberglass reinforced filler, like Tiger Hair, or it will probably crack after a few years. Also a metal frame is important to give it some strength.
I made the plate out of a scrap of aluminum. Steel would work, I just happened to have a scrap of aluminum, plus soft aluminum is easier to work with. A stiff plastic would work as well. I got the shape by drawing an oval in Microsoft Word, then set the length and width to be a little smaller than the knob. I mounted the plate on the knob before I had sanded it to shape. That way I was able to make the knob match the shape of the plate.
Also... I noticed the link to the rocker switch doesn't always work. If you get the error page, just put the part #, 7500011 into the Del City product search box.
jp
/ selector valve #69
If anyone is seriously thinking of using this valve, the supply at Surplus Center is dwindling. Last week they had over 30, at last check it is down to 26. The price quoted to me by a local Cat dealer was $734.82. Not trying to be an alarmist, everyone make your own decision.
One thing to consider, what if your valve goes bad and SC is out of them? Hopefully the only thing to fail would be a solenoid, and hopefully they are available separately.
Like most things, you pays yo' money and you takes yo' chances.:)
jp
/ selector valve #70
My local Cat dealer showed all the parts available for this valve. That said I would bet $150 for another valve is cheaper than any part from Cat except maybe orings. I know if I got another one for parts it would be on the shelf for a long time. Hard to justify
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
17101 (A55851)
17101 (A55851)
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
