selector valve
/ selector valve #91
Here is what I figured out. I think it is the regen that is causing the problems. I think I am going to change things around so I use the raise and lower function to control the selector valve.
Bill
You got it! The regen should not be active for the whole travel of the joystick though...
/ selector valve #92
I switch things arround this morning so I am using the raise and lower functions on the FEL valve and every thing is fine.
kennyd, is there any way to adjust the regen. The regen seems to function through the whole dump cycle whether I move the joystick a little or move it to full dump.
Bill
/ selector valve #93
Bill
No adjustment...you must have a 3-position valve on your machine...read THIS post for more info.
/ selector valve #94
Well I am still having problems with this valve. The garpple works perfect now. The problem I am having now is with the up and down with the loader.When I am below 1500 rpm's every thing is fine. When I raise the rpm's higher and raise the bucket it goes slower. It goes down fine. So I switched the lines going into the selector valve from the FEL valve and switched the lines going from the selector valve to the lift arms so I an useing the valve in the other direction. Now it goes up fine but come down slow.I am going to dissamble the valve tomorrow and see if I have some kind of blockage.
Bill
/ selector valve #96
I do not understand your switch wiring. look at my attachment.
you need two double pole switches. Do nothing the priority port flows.
Pick sol 1 and 2 and port 2 flows. Pick sol 1 and 3 and port 3 flows.
  • DPST SWitch for Selector valve.pdf
/ selector valve #97
the sketch says it can be wired up with one DPDT switch? can you make a sketch of it please.
/ selector valve #98
You need two double pole switches. Unless you have a rocker center off, double pole one way and double pole the other way.
My sketch showa 2 separate switches. Thats how I did it. I just looked at the switch you picked. It is a rocker on off on DPDT.
It should work I think the center commons get tied to +12. Then the NO contact on each side of one pole get teid together and to sol 1. The other pole NO one contact to sol 2 and the other contact to sol 3. I think.
/ selector valve #99
OK, I think I got it now. It should be like this?
  • DPDT Switch.pdf
/ selector valve #100
yes HMM yes was to short to post had to add comment
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2020 SAVANA 3500 4X2 S/A 16FT BOX TRUCK (A59906)
2020 SAVANA 3500...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2019 FREIGHTLINER CASCADIA  T/A  SLEEPER TUCK TRACTOR (A59906)
2019 FREIGHTLINER...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
