Seldom do I plug a product.
/ Seldom do I plug a product. #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
If you are in a bind having to remove a pressed in bearing or bushing by pulling from the I.D. Sizes 11/16 ro 1-5/8, then this little tool is well worth it. I looked all over and what I found either looked like junk mush metal, or was SNAP-ON tool like expensive.
I was impressed with the quality. It removed the bearing at the bottom of a manual steering box and the top bearing from the shaft column.
Amazon.com: OTC 4421 Pilot Bearing Pulling Attachment: Automotive
/ Seldom do I plug a product. #2
Looks like a useful tool to have around.
/ Seldom do I plug a product. #4
I you run a bead of weld around the inside of a bearing they will fall out.
Sometimes one must work harder because the tools to work smarter aren't within reach. Brains vs. Brawn but either will pull a bearing.
/ Seldom do I plug a product. #5
They are a handy tool. Another way if you can find a piece of bar the same diameter as the shaft is to fill the bore with grease, put the piece of shaft up to the hole and give it a smack with a BFH.....Mike
/ Seldom do I plug a product. #6
Nice tool:thumbsup:
If the bearings should be replaced it has happened that I've taken a bit of threaded rod and welded to the inner ring and used a slide hammer
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
Frontier RT3062 (A64126)
Frontier RT3062...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
2023 New Holland Boomer 45 Tractor (A65579)
2023 New Holland...
