Seldom do I plug a product.
/ Seldom do I plug a product. #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
If you are in a bind having to remove a pressed in bearing or bushing by pulling from the I.D. Sizes 11/16 ro 1-5/8, then this little tool is well worth it. I looked all over and what I found either looked like junk mush metal, or was SNAP-ON tool like expensive.
I was impressed with the quality. It removed the bearing at the bottom of a manual steering box and the top bearing from the shaft column.
Amazon.com: OTC 4421 Pilot Bearing Pulling Attachment: Automotive
/ Seldom do I plug a product. #2
Looks like a useful tool to have around.
/ Seldom do I plug a product. #4
I you run a bead of weld around the inside of a bearing they will fall out.
Sometimes one must work harder because the tools to work smarter aren't within reach. Brains vs. Brawn but either will pull a bearing.
/ Seldom do I plug a product. #5
They are a handy tool. Another way if you can find a piece of bar the same diameter as the shaft is to fill the bore with grease, put the piece of shaft up to the hole and give it a smack with a BFH.....Mike
/ Seldom do I plug a product. #6
Nice tool:thumbsup:
If the bearings should be replaced it has happened that I've taken a bit of threaded rod and welded to the inner ring and used a slide hammer
Street Sweeper (A60352)
Street Sweeper...
Sellick S80 (A60462)
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
CONEX BOX (A65643)
CONEX BOX (A65643)
