Seldom do I plug a product.
/ Seldom do I plug a product. #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
If you are in a bind having to remove a pressed in bearing or bushing by pulling from the I.D. Sizes 11/16 ro 1-5/8, then this little tool is well worth it. I looked all over and what I found either looked like junk mush metal, or was SNAP-ON tool like expensive.
I was impressed with the quality. It removed the bearing at the bottom of a manual steering box and the top bearing from the shaft column.
Amazon.com: OTC 4421 Pilot Bearing Pulling Attachment: Automotive
/ Seldom do I plug a product. #2
Looks like a useful tool to have around.
/ Seldom do I plug a product. #4
I you run a bead of weld around the inside of a bearing they will fall out.
Sometimes one must work harder because the tools to work smarter aren't within reach. Brains vs. Brawn but either will pull a bearing.
/ Seldom do I plug a product. #5
They are a handy tool. Another way if you can find a piece of bar the same diameter as the shaft is to fill the bore with grease, put the piece of shaft up to the hole and give it a smack with a BFH.....Mike
/ Seldom do I plug a product. #6
Nice tool:thumbsup:
If the bearings should be replaced it has happened that I've taken a bit of threaded rod and welded to the inner ring and used a slide hammer
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
LOOK! (A63116)
LOOK! (A63116)
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
