Seized Drain Plug
   / Seized Drain Plug
I'm thinking that's what's going to happen. For now everything is back together, and once it warms up a bit I'll run the tractor to temperature to make sure there's no air lock and check for leaks.
   / Seized Drain Plug #43
After you fill it, leave the cap off of the radiator and gently squeeze bottom and top radiator hoses, that should push enough air around to get rid of any air locks and get the cooling system ready to go.
I might leave the radiator cap off for the first few minutes after you started just to make sure that if it works any air out you can replace it with coolant.
Aaron Z
   / Seized Drain Plug
Aaron Z
Thanks for the tip. And thanks to everyone who answered.
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2022 Schulte 2500 Giant Rock Picker (A55314)
2022 Schulte 2500...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
202479 (A54757)
202479 (A54757)
Frontier FM2015 (A53314)
Frontier FM2015...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
