Seized Drain Plug
   / Seized Drain Plug
I'm thinking that's what's going to happen. For now everything is back together, and once it warms up a bit I'll run the tractor to temperature to make sure there's no air lock and check for leaks.
   / Seized Drain Plug #43
After you fill it, leave the cap off of the radiator and gently squeeze bottom and top radiator hoses, that should push enough air around to get rid of any air locks and get the cooling system ready to go.
I might leave the radiator cap off for the first few minutes after you started just to make sure that if it works any air out you can replace it with coolant.
Aaron Z
   / Seized Drain Plug
Aaron Z
Thanks for the tip. And thanks to everyone who answered.
2017 Peterbilt 220 16ft Box Truck (A55852)
2017 Peterbilt 220...
2016 FREIGHTLINER CASCADIA DAYCAB (A55745)
2016 FREIGHTLINER...
2007 CATERPILLAR D5G XL CRAWLER DOZER (A52707)
2007 CATERPILLAR...
2015 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2015 COMPTANK...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
