Seized Drain Plug
   / Seized Drain Plug
I'm thinking that's what's going to happen. For now everything is back together, and once it warms up a bit I'll run the tractor to temperature to make sure there's no air lock and check for leaks.
   / Seized Drain Plug #43
After you fill it, leave the cap off of the radiator and gently squeeze bottom and top radiator hoses, that should push enough air around to get rid of any air locks and get the cooling system ready to go.
I might leave the radiator cap off for the first few minutes after you started just to make sure that if it works any air out you can replace it with coolant.
Aaron Z
   / Seized Drain Plug
Aaron Z
Thanks for the tip. And thanks to everyone who answered.
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2010 INGERSOLL RAND  G40 GENERATOR (A55745)
2010 INGERSOLL...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
2011 WESTERN STAR  4900 SB (A55745)
2011 WESTERN STAR...
2012 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2012 POLAR TANK...
