Security & Theft Securing tractor from theft
/ Securing tractor from theft #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I have a small ranch with no infrastructure 70 miles from my resident. I get there every week, 2-3 days at a time. I have a large 120hp tractor there, and stealing it...they would need to work at it. But, I'm fixing to buy a 50-70hp tractor, and will at times have to leave out there.
How best to secure, or disable from starting. As most probably know, many of these tractors can be started with a screwdriver. And keys...one key fits all it seems as well.
Ideas to deter theft?
/ Securing tractor from theft #2
You could do something simple like removing one or both of the front wheels and taking them with you. That would deter the kids.
If a pro wants your tractor, it's his. No matter what you do all he needs is a tilt bed car hauler with a stout winch to drag your tractor onto the hauler.
/ Securing tractor from theft #3
Turn the front wheels hard left or hard right and chain the steering wheel there. It will at least be inconvenient to steal. Like flusher said, you can't stop the determined ones. Flusher's idea is more secure.
Seems you'll probably have to decide how much peace of mind you want versus how much inconvenience.
/ Securing tractor from theft #4
Check if your tractor will fit into a shipping container. If it will, then you could buy one and use it to store your tractor+tools+etc until you are living fulltime on your property.
/ Securing tractor from theft #5
If they want it they will take it. You should do a search through the site to see some ideas, there are really not that many as these tractors are simple and keys universal.
IMO Out of sight is the first line of defense, then I would back it up with a security camera so at least you have a fighting chance of getting it back if it is stolen...
/ Securing tractor from theft #6
Id take off the front wheels and put a GPS tracking device on it in case the bad guys are determined and bring their own wheels.
/ Securing tractor from theft #7
One of the dealerships I went to visit and try out their tractors had taken a fuse of the starting system out so that the tractor could not start without it in. It was a simple matter to put it back in and yet not a noticeable thing as to why the engine wouldn't run. That along with chaining the steering wheel (as mentioned) or removing the front wheels might be deter folks enough.
/ Securing tractor from theft #8
My thought is, if a tractor has a FEL, put it into the full dump position, resting on the ground. Disable the starting system, as pax said. Chain steering wheel if you have one bolt cutters or a torch won't touch. Make sure your insurance is paid up. You might also remove the seat.
/ Securing tractor from theft #10
GCLnIndiana said:
..put a GPS tracking device on it ...
Done deal, and they will never know it. Relatively inexpensive for a signal omitting device.
As said earlier, out of sight, out of mind but a GPS will take you right to it, if indeed you know it has been stolen before a thief < spit > pats it down for said device.
/ Securing tractor from theft #11
The best methods are ones that make the thief work. Taking the cranking fuse is ok, but putting a locking fuel line to the pump is better. It will crank and run, but then die. Who wants to steal a broken tractor? Adding a relay to the starter solenoid so it will crank for 2 seconds, then reduce the voltage so the starter slows down and quits, then won't crank. Would take an team of electronics experts or a high school nerd 15 minutes to design, but worth while.
Getting a racer's quick disconnect steering wheel is a good thing too. Putting a pair of locking fluid lines, one on each of the lines to the steering cylinder is good. Turning the wheel all the way left (or right). Take the steering wheel and lock the lines. They they can only turn the steering wheel nub with a vice grip and with the lines locked, they can't straighten the tires.
I would also get a couple of the IR game cameras. Cover the vehicle approaches and the machines and HIDE them or they will get stole too!
Now for the fun stuff. If you were an electronic's expert, you could have an IR sensor detect a crook on the seat, then remotely have a laser pointer from way off turn on pre-aimed to be on the crooks chest. Leave a note on the steering wheel "if you see a red dot on your chest, you have 7 seconds to leave or die". You may need to wipe the smell off the seat ....
/ Securing tractor from theft #12
John,
You da man!! great idea..:D :D Over the winter I take one front tire off raise all wheels off the ground and support the tractor on jack stand with batteries removed. I wrap a good size chain to the front axle and thru my 700 lbs tiller and what ever else I can. These thieves are there for a quick bite most of the time. none of these strategies can stop a determined thief that had plenty of time. just got to make the bite as least attractive as we can so it would not worth the hassle for them. it is easy to rig up IR motion detector to variety of different things to scare them off. I suppose a simple sign saying " Achtung!! wireless surveillance camera in operation". Of course, I give them the benefit of doubt to be able to read and understand what they read.
JC,
/ Securing tractor from theft #13
Park it at a neighbors house. As you know.. if a theif wants it.. he will get it. Tractors are about as easy to hotwire as bicycles... Don'tr waste time on goofy cutouts.. etc. a piece of wire with gator clips usually does away with it anyway..
soundguy
/ Securing tractor from theft #14
GPS lojack
do you have any power out there, or at least solar power to run equipment?
If you have a building to park them in, alarm the building
Cameras that have < 1 lux night vision capability, with remote feed to you
any trick you feel comfortable employing that you can remember to disable the unit form operating.
/ Securing tractor from theft #15
I hook as many implements up as possible (disks), and then store others in the way to impede easy/quick loading. To slow down a thief (or kids) I also leave the tractor 1) in gear; 2) PTO in on position; 3) bucket in dump position with tooth bar buried; and 4) keep it out of sight. Someone in a hurry might overlook the existing lockouts for transmission and PTO.
Also consider opening the hood and leaving a troubleshooting manual with "extra" parts laying around like you're in the middle of fixing something big. Who wants to steal a tractor thats already broken?
Or if you're really good, move your bee hives onto the seat!
/ Securing tractor from theft #16
isn't insurance easier? I guess it would depend on how often tractors get stolen. Never heard of it in Massachusetts, so I'd guess its pretty infrequent around here.
/ Securing tractor from theft #17
I love number 2). Not something that you would think of immediately.
I am in the same position in that I leave my tractor for weeks at a time. I keep mine in a locked garage, main fuse removed and chained with the harrows along side so that it will not get out the door. Next trip will also have the PTO engaged. And it is insured!!
Cityfarma
/ Securing tractor from theft #18
I don't know about MA...but...
Irish Terrorists Suspected in Tractor Thefts
A crime wave is sweeping England's green and pleasant land. The southwestern county of Somerset has been known for it's beautiful rolling hills and it's farming community, but now it's involved in a plot authorities believe might be linked to terrorists. The crime- tractor theft. From a thieves' perspective, the thefts make sense: Tractors can cost up to $200,000 each. $2 million worth of farm equipment is disappearing every week in Britain. The Gloucestershire Constabulary, is leading the counterattack, code named Operation Mermaid. Officials leading suspects are Irish terrorists. Investigators at the National Plant and Equipment Register, a company that helps people recover stolen equipment and machinery, said crime is diversifying: from stolen paintings, to stolen tractors which are being shipped as far as Australia. And tractors are easy to steal. Usually one key fits into any John Deere tractor. Tractors are generally easy to drive and very hard to identify. All Ford tractors are solid blue and every John Deere tractor is green. ABC News: Terrorist Thieves Reap Farm Bonanza
/ Securing tractor from theft #20
Insurance policy. Mine is ridiculously inexpensive.
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
PREVIEW DATES AND TIMES (A61166)
PREVIEW DATES AND...
2014 NISSAN NV CARGO VAN (A59906)
2014 NISSAN NV...
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
TANK MANIFOLD (A58214)
