securing mini-x at remote location
/ securing mini-x at remote location #21
Also parking the machine with the cab perpendicular to the tracks helps - hard to winch it on a trailer and take off with it not starting and sitting in that position.
That seems like a really good idea.
/ securing mini-x at remote location #22
Battery disconnect, fuel shutoff, a few chains to trees, plates that go over the dash.
Maybe you could even remove a Joystick controller.
Depending how your diesel is shutoff, disconnect the electrical or is oldschool and shut off with a kill lever, unhook the cable or level in the off position.
Yeah hold the fuel shut off closed. Zip tie or bailing wire.
In addition to a beefy tongue lock, I used to pull my trailer next to and up against trees in my yard so you could only get it out with something small enough to move the trailer backwards without hitting the trees with the vehicle. It was too heavy for a person to move and too many obstructions to back a truck up to it. That cost me a tail light once though....
Also after a rain, I couldn't access my trailer without making a huge mess.
/ securing mini-x at remote location #23
No idea if it works or not, never went missing, on my BX way back up under the fuel tank I placed a valve in the line, mainly to keep from pinching it when changing the filter. With the ground clearance of a BX it is a real crawl to find it much less turn it. I leave it at the church from time to time and always park it under the parking lot lights. The local Sheriff deputy told me after a robbery at my house that lots of light on property is a good deterrent. Stops the low fruit pickers especially. Had the power company install a big light on the power pole close to the garage and tractor parking lot. No more robbery so who knows.
Ron
/ securing mini-x at remote location #24
If I’m leaving my trailer somewhere I don’t trust I just set the hitch on the ground without lowering the jacks. I figured since it’s over 1,000 pound on the hitch empty ( L3800 won’t pick it up ) that there’s zero chance of 2 guys lifting it up and any means to lift it up would take longer than cutting of any practical locking device.
/ securing mini-x at remote location #25
Ron
I guess if they planned on driving it off you’d catch them down the road but I’m guessing it would still run for several minutes like that. Plenty of time to drive on a trailer.
/ securing mini-x at remote location #26
Well hidden kill switch - park with boom perpendicular to tracks - good insurance policy.
/ securing mini-x at remote location #27
when my machine is at the lake typically I disconnect the lift pump and turn the boom 90 degrees extended and on the ground, be hard to load the machine in this condition, with the pump disconnected it does start but runs less than 10 seconds
/ securing mini-x at remote location #28
Put game cameras on the the access road/path in and out of your property. At least you'll have something to show to the LEOs if it does get stolen/damaged. Additionally don't leave the trailer with the excavator. And as Eddie said, cordless grinders can defeat just about any locking mechanism, so his idea of a kill switch will slow down or stop most common thieves. It's tough to try and outwit determined criminals.....
SimS
Cameras a good idea. Bottom line with my 18V 4-1/2" cut off grinder, I can get thru any lock and bring a battery and fuses with me if you have the time. With no one around, they have all day.
What is the nearest neighbor or something? Maybe you can work out a deal to store it near by. Just a thought. I have the same concerns with stuff at my house and other property. Trailer especially. I have found no way to protect them that can't be undone in about 10 minutes with the right tools. They have GPS trackers now that are cheap. May be worth it. And get a solar battery charger for it and mount to the roof.
/ securing mini-x at remote location #30
As a heavy equipment mechanic, I can get past most of the stuff you guys mentioned. Your best bet is a hidden gps and yank the starter if possible. Maybe quick disconnect s on the positive cable and whatever wires run to the starter.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
TOYOTA 8FGCU30 FORKLIFT (INOPERABLE) (A60736)
TOYOTA 8FGCU30...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
CFG Industrial H15R (A60463)
CFG Industrial...
