Screening Plant Project
/ Screening Plant Project #1
akpilot
Wasilla, Alaska
NH TC40DA
I have the need (want) for a screening plant to screen topsoil, when they first built the road in front of the property that I own they piled 3-4 hundred yards of rocky topsoil on one corner. The last couple years I have built a new house and shop, now it's time to landscape (actually going to use my tractor for it's intended purpose):) . I have done some searches on TBN and have got some good ideas. Anyway this is what I come up with, a combination of stuff I had on hand, and a little new steel (so the local supplier could feed his kids):) Wow is steel expensive:eek: Before i clean it up finish and paint, I wanted to test it, but the weather went back to winter like:mad: so I will have wait a few weeks. Let me know what you guys think.
/ Screening Plant Project #2
Wow! Looks great! Wish I was that far along.
Is the angle adjustable on the table? Too me, it looks very steep, I would think I would want mine flatter, but will be watching the project with interest.
No, but I have a plan if need be.... for now the cross bar holding the springs is welded in place but if need be I can move it if I need to go down (flatter) or change the spring bases if I need to go up. Years ago my dad owned a pit and a screening plant that had a hyd. adjustment on the angle. These days my "forgeter" works better than my "rememberer":( . If I remember correctly we adjusted the angle depending on the product, very flat when making mason sand and fairly steep for maiking septic rock. So right now it's a big science project, that I can't wait to try! I added a pic of the cross bar and spring bases so you can see what i'm talking about.
/ Screening Plant Project #4
Great Looking piece of equipment!! Last year I had a need for some screened sand (for mortar). I built a simple screen and hung it from trees via rope. We found a need to place a fixed divider between where the sand would fall and where the rocks fell to separate the two materials.
Again Great Project!!!
/ Screening Plant Project #5
Dandy!!!
Nice classic old Briggs too.
After it's painted I plan on sheeting the inside of the frame with 1" ply or somthing, to stop "intrusion" from the back and sides. I think that will work.
/ Screening Plant Project #7
I will be watching with interest because I could use one of those for the projects I'm woking on. How big is it (dimensions)? Bill
The Screen is 96" by 64" No particular reason for that size, it use to be a roof rack off a van that I bought at a auction. The bucket on my tracror is 72" so I think it is about the right size. the front of the screen is about 90" off the ground, which will just be high enough for the FEL full up in the dump position. The old Briggs and and other pieces are off an old "ruff cut" mower that was given to me. The motor hadn't been started in 15+ years, I checked for a spark put some gas in it drained a little through the carb, 3 pulls it started :eek: a little fine tuning and it runs like a top! I'm not much of a small engine mech so I was happy I didn't have mess with it much.
/ Screening Plant Project #9
Great looking project!!:cool: Could you show a pic of the vibrating mechanism? Look forward to when you can "test it out."
Mike
Mike
Hey Mike
Here is a couple pics, the vibration unit is part of the old mower, I simple cut off the blade and added a counter weight (3/8"x2"x3") to one side. I'm sure I will have to experiment with amount of weight, however it shakes pretty well as is, I even stood on the screen to see if that changed the amount of vibration and it didn't seem to. So it should be good for testing. As soon as it thaws out:mad:
/ Screening Plant Project #11
Looks good for a try. thanks for the pic. I saw on the weather that it had truly turned winter again there. We have daffodils blooming and the fruit trees are starting to pop. But we had a VERY mild winter.
It will be interesting to see how long that spindle can take an out of balance situation.
Mike
PS. You will of course put an OSHA approved cover over everything moving or rotating, right? ;)
It was spring like for a week or so, we had Mallard ducks in the spring feed pond below the house, the trees were buding......Wed it started snowing dropped to 12 F and snowed about 8":mad:
Yes I will be putting a cover over rotating parts, my first test had a couple tack welds and I had a little more throttle than I relized........A few seconds of pure mayham!!! I dove under the boat, luckily all the loose pieces fly the other way......needless to say I did a little more welding before another attempt!!!
The spindle has a grease zerk, but...who know how long it will last:confused:
/ Screening Plant Project #13
Do you happen to know a good source for drag-racing scattersheilds? May need that more than covers... :confused: :p :D :D :D
/ Screening Plant Project #14
OK, I have had this project in mind for quite some time. I almost built one last summer, but did not have the time. I have been working over plans in my head, then I came across this website!
A fundamental difference in my vision, and just about every design I have found on this site, is that all the ones on here seem to want to make the screen bed, and consequently the screened material, move vertically. That is shake the bed up and down. I first thought about that, and then started to lean toward shaking a screen from side to side. My thinking is that it would take much less brute force to shake a given weight of material from side to side, then to left it and drop it. I was thinking of powering a flywheel with an electric motor (maybe from a washing machine) with belts (just in case it does need to slip). The flywheel would be connected to the shaker table with a connecting rod, and would work similar to a steam engine. The table then is suspended from wither rods, chain or maybe even springs. You do have to have a strong common connection point at the top of the table as a pivot, but is there a reason someone has not designed a table in this fashion yet? Am I missing an obvious design flaw?
toivo1037 Welcome to the site.
I'm hardly an expert; however I think you are overestimating the force required to move the screen. The vibration unit is spun via a belt, so not much actual force is put on the motor. My concern with a side motion is root balls or a clump of grass will get on the screen and simple go back and forth, the vibration units will move them down and off the screen. Again i'm far from an expert!:)
The ground has finally thawed enough to test the screening plant:) Overall it worked real well, a few items I will need to re-work. So it's back to the shop for final weld and paint.:D
/ Screening Plant Project #17
wow, looks like it works fantastic! nice job...
i used to work at congoleum on the granulator machine that screens off fine particles of chipped pvc sheets to conform sizes for the higher end products like fashion-floor, and esteem. since then i always wanted to build something like you have! 'been about 25 years and it's still just up in my head ;)
/ Screening Plant Project #18
I was wondering if you could put a sheet of plywood "under" the screen angled back towards the tractor.
That would slide the "screened topsoil" back out towards the tractor so that you did not have to scoop under the vibrator to get it out.
Or is that not a problem?
/ Screening Plant Project #19
One thing I saw in your first set of pics when it was in the garage is that the muffler is pointed towards the belt. You may want to turn that slightly or reroute it so that the belt doesn't get all that heat put on it. Just my .02!
Marcus
Thanks for all the nice comments and suggestions.:)
Sam2145871 Very observant....Yes it does, the deflector is adjustable I didn't take the time to fix it yet, during the test the belt was bouncing enough that they didn't seem to heat up. I still have to build an engine guard, so when that's done, I will figure out the best direction for the exhaust. Welcome to the site!!!!
AlanB When it's finished there will be plywood on the inside of the frame to maintain separation and contain the screened material , the overall depth is not enough that I could accidentally have a rock hit hood of my tractor, so I don't think it will be a problem.:)
Zero Turn Mower (A59231)
Zero Turn Mower...
2019 KUBOTA M6S-111 TRACTOR (A59823)
2019 KUBOTA...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2019 INTERNATIONAL LT625 DAY CAB (A60736)
2019 INTERNATIONAL...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
MMS MS750 Remote Control Lawn Mower (A60463)
MMS MS750 Remote...
