Scratch / Lift Start TIG Welding
/ Scratch / Lift Start TIG Welding #21
The radiation aspect of TIGing with thorium is trivial, but avoid breathing the DUST from grinding thoriated tungsten.
I do mine outdoors.
/ Scratch / Lift Start TIG Welding #22
Yes the radioactivity of thorium is quite trivial. You have smoke detectors in your house? Those have Americium in them. Radioactivity is often described by half life of the element. The shorter the half life the more radioactive it is. Thorium has a half life of 14 BILLION years. Americium has a half life of ~400 years or so. Plus thorium decays to an alpha particle. A piece of paper stops alpha. As long as you do not inhale or ingest an alpha particle generator, there is essentially zero risk, especially with such a low level material. And furthermore...keep in mind that there is only 2% thorium in the tungsten. It's not exactly like drinking Fukishima reactor water...
And this:
Radiation concerns and 2% Thoriated Tungsten - WeldingWeb™ - Welding forum for pros and enthusiasts
Not definitive, but frankly not something to worry about all that much. Just don't suck in thorium dust.
My startup cost was right at 350 bucks for everything. Torch, 125Cuft cylinder full of argon, regulator and the tungstens. Gloves and some TIG rod. I did buy the cylinder, so you could get by with a rental for less up front. Of course I already had the welder the Everlast PA160
James K0UA
Hmmm ... Well, I'm working on the "getting a welder" portion of things so I think I'm a couple of steps behind! :)
/ Scratch / Lift Start TIG Welding #24
Ok well the new PA160sth comes with a TIG torch a Regulator and has HF and Lift start. It says it has a built in gas solenoid, and push button on the 17 series torch. The foot pedal is extra though. So all you would need is the cylinder (either buy or rent) and you would be good to go with DC stick and HF or Lift start TIG, with optional foot pedal control.. I can't vouch for it as I don't have one but I would like to have one:) $489 list, but make Mark an offer , I bet he would take less.
James K0UA
James K0UA
That's one unit I've been looking at. A bit out of my reach at the moment but I'm seeing how much I can muster up. Also looking at the Longevity Stickweld 140 and the Everlast 140st as they are less expensive models. Thanks for the info!
/ Scratch / Lift Start TIG Welding #26
If the stickweld 140 welds anything like my stickweld 250, it would be a great machine. If you can swing it, one with adjustable arc force is worth it.
/ Scratch / Lift Start TIG Welding #27
i placed my order yesterday for the MIG/Sick Arcmate 205P with Longevity. I wanted a MIG and thought the stick part would be frequently used as well.
I got the monthly 40% off special. I ordered it with a regulator for the MIG part.
40% off!?! Wow, how did you swing that? :confused2:
/ Scratch / Lift Start TIG Welding #29
/ Scratch / Lift Start TIG Welding #30
That is the monthly special for the first TBN member to post in response to Longevitys Monthlys Special. I had been watching for it and was the first to respond with a post.:thumbsup:
I might have to try and get it in a few months, it will make the small mig I need even more affordable. It will go well with my stickweld 250.
/ Scratch / Lift Start TIG Welding #31
I'm just in the process of getting into lift arc tig. Still need my 14 pin foot contactor. Stay tuned!
/ Scratch / Lift Start TIG Welding #32
I am anxious to try my hand at MIG welding. I have stick welded for almost 30 years on an as needed basis. Not a pro mind you but able to utility weld. I have always wanted to try it out. The Stick/Mig Arcmate 205P seemed like a good way to go.
/ Scratch / Lift Start TIG Welding #33
If it stick welds anything like my stickweld 250, you have a great machine.
I am thinking of getting the arcmate 160d when I get a mig for 2 reasons. #1 I only really need it for thin stuff, I have a 250 amp dc stick welder for heavy stuff. #2 I have no space in my shop, so every bit of compactness (I think thats a word) counts. The 110/220 will be nice too.
Depending on your circumstances, being able to use the 110v in a pinch for low amperage jobs can be a life saver in the field.
/ Scratch / Lift Start TIG Welding #35
It's not bad once you get comfortable with it. We trained many students to pass 6G pipe tests in nineteen weeks. Billions of dollars of pipeline and boilers and nuke plants are welded every year that way.
Same here. I have been in the heavy construction industry for over 45 years and the only time we ever use HF start is with Aluminum or some of the highly exotic metals like Titanium and Zirconium. With just a little practice at starting, you will eliminate any fouling of the tip when starting. First lesson is dont put a needle tip on your tungsten so it doesnt break off as easy.
Scratch start rigs work well for just about anything around the farm and you can run them on any machine that has a postive and negative which is everything including the AC machines.
I can give you lots of tips on TIG welding if anyone is truly interested in doing something other than MIG or FCAW welding. Just PM me.
Thanks for all of the information. This has been a great thread.
/ Scratch / Lift Start TIG Welding #37
I strongly debated on getting the Arcmate 160 but I opted for the 205P for the pulse feature and the ability to stick weld at higher amperage. The 120/240V feature is a good option om the 160.
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
Lot of (4) Square Tube Gates (A66408)
Lot of (4) Square...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2009 Bobcat T190 (A64126)
2009 Bobcat T190...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
