Scored a one shank ripper-subsoiler
   / Scored a one shank ripper-subsoiler #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Found this one shank subsoiler "ripper" recently and thought you guys would like to see it and my plans. These are great in clay soil to fracture the plow pan and allow better drainage. This one weighs 230 lbs but had been twisted by a guy that changed the grade 2 shearbolt for a grade 8 and hooked it to 150HP. Anyway, a welding shop fixed it and I found it. It's good for maybe 100 HP and down.
The photos show it in two pieces since it's so awkward to handle and I needed more welding done. You need a little vision. I had the side plates cut off and new 1/2" plate ones added that also give a cat I hookup 5 inches below the cat II. You can see the new plates in the photo. In a separate photo is the ripping shank that is maybe 28" long and is really heavy. You can also see a little stub eye I welded on the back to put a parking stand on. This is one awkward piece of equipment of unknown but quality origin.
Anyway, my plan is to use on my bigger JD5520 (75HP) around the house plus also hook it to my Kubota L4300 for local gardens. I'll go 14" deep.
As well, I'm going to clean it up and paint it JD green and put a Deere decal on it. Laugh, and I'm not selling, but green paint brings way more resale $$ around here.
I'll post more photos as work progresses.
   / Scored a one shank ripper-subsoiler #2
I like it!:thumbsup: It looks tough. Slop some paint on it and put that bad-boy to work.
James K0UA
   / Scored a one shank ripper-subsoiler #3
Congrats on nice find ! :thumbsup:
Hope you post some action pic's of it when you can.
Man that thing looks massive !
Why don't you leave it yellow so people will think it's a KK or Countyline and they won't want to steal it ! :laughing:
Take a look at this,very simular:
Worksaver Small Tillage Equipment check out R-130 on this page)
Boone
(just kidding TSC brothers and sisters) :D
   / Scored a one shank ripper-subsoiler #4
its amazing the difference running sub moisture plow makes. we run an offset 6 shank on our farms about 10 inches deep. just got done running it today over some pasture ground for a friend and tore a plow off in the middle( shank trip didn't work) so mine needs some welding too
   / Scored a one shank ripper-subsoiler #5
Beefy!
Hard to imagine twisting that.
Can you lift it high enough on your 3pt to transport without gouging the landscape when you are on uneven ground?
   / Scored a one shank ripper-subsoiler #6
All too often those are called a Utility Line Locator non-descriminating - water ,gas, fiber optic, electric - it makes that stout little feller no difference. Be safe and have lines located before you dig.
bullbreaker---good catch in post above. It does look like an early version of a Worksaver model. It is painted that "puke yellow" color but these things are so desirable I can get away with a quality Deere green paint job with decals.
Baby Grand---Clearance on the L4300 is why I had that step-down plate welded to the sides. It "raises" the implement on a small tractor sufficient to clear the ground--and clear loading on my trailer. That's the theory at this point so I will update. And yes, it was twisted pretty good. He was using it to pull stumps and replaced the grade 2 shear bolt with grade 8 because it kept shearing. OK, sure...
SandburRanch--Yes, indeed they are "Utility Line Locators" and if anyone else is reading this with similar plans don't go deep unless you are certain what is below. Phone wires especially but old timers often ran electrical stuff too shallow 'twix the house and barn.
Deere9986--Yes, the difference is amazing in drainage and root growth. In ripping my black dirt clay the yields have spiked and drainage dramatically improved in the spring. These are also used on the edges of fields to "root prune" neighboring line trees from stealing crop nutrients.
Got the wire wheel out and ground the loose paint and stuff the best I could.
Then I washed it it with a scrub brush and detergent. Here's a couple photos of it after the wire brush and cleaning.
The thing in the background is a metal table that needed paint.
Then I primed with Rustoleum rusty metal prime srince I have had great results with it. I also picked up a can of Deere acrylic enamel green but that's a couple days off. Here's the primed parts.
   / Scored a one shank ripper-subsoiler #10
What's the tab for that's hanging out the rear with the hole it it? That's a stout piece!
KUBOTA M955 DUAL SPEED TRACTOR (A57192)
KUBOTA M955 DUAL...
CATBKTSSL_78 (A55787)
2015 Ford Focus (A51694)
2015 Ford Focus...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
Peterbilt (A51692)
Peterbilt (A51692)
SKID STEER FORKS (A53843)
SKID STEER FORKS...
