beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,608
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
"" <font color="blue"> I immediately dropped the bucket which seemed to be what kept it from going on over </font> ""
Sure did the right thing by lowering the bucket. And it is sometimes counter to what the instinct might tell you. As you see the loader/bucket drop (because the rear wheel is coming up) it sometimes is instinct to 'raise' on the bucket causing more of a problem. But when losing traction on the rear end because of no ballast, lowering the bucket to get the load back onto the rear wheels is the absolute right thing to do. That is a good 'habit' to get under your skin. It may come in handy if you are going down a hill, with a bucket full, and start to slip. You can't use the rear brakes, nor the back pressure on the engine, nor will 4wd help. The only solution is to drop the bucket and get the load on the ground so all the other things can work the way they are supposed to work.
