satoh beaver
/ satoh beaver #1
josolar
I have the opportunity to purchase a 1978 satoh beaver. It has been gargaed its whole life and looks to be in great condition. It comes with a Johnson frt loader and a mower. Here is the problem. The owner tried to put the tractor into low gear and it didn't want to go, so he forced it in. After he did that the tractor has not been running. He said it sounds like the tractor is operating with the brake engaged, or when you try to lift to much with it and it stalls out. The engine turns over, but it will not run. It shifts into gears 1-4, but it is back in high gear and it won't go into low. Anyone have ideas of what the problems is? cheap or expensive fix? thanks.
Josh
/ satoh beaver #2
Think I'd look in the transmission gearbox and see how much oil is in there. Does it have many hours on it?Best case scenario, just gunked up, probably still have to split the case though. Is it cheap enough to play around with for awhile, or do you want the use of it right away?
/ satoh beaver #3
Also, ask the owner which way the pto turns. That one may be one that has the counter clockwise rotation which should influence your decision along with other potential repairs.
/ satoh beaver #4
Since the original problem was that it wouldn't go into gear, I'd look at a problem with the shift forks. Possibly 2 gears are engaged at the same time.
/ satoh beaver
Would the problem with the transmission affect the starting?
The enging turns over pretty good, but just short of having the engine kick of and run. While trying to start the engine spits out black smoke, but it will not start.
I have the battery charged, pluged in the block heater, glow plug works. (it is only about 30f outside, and it hasn't been started in awhile.)
I was thinking of bleeding the fuel line. Any suggestions.
/ satoh beaver
Got it started. Hooked battery up to charger, put throttle at full, and a bit of starter fluid in the carb. The tractor just had not been run in so long that it was hard to get going. Only problem now is it that it is stuck in high gear. 1-3 and reverse all work fine.
The pto is counter clockwise, but it comes with a mower that is on its way.
Why is countert clockwise bad? no attachments made for it? the tractor is a 1978 satoh beaver s-370.
A family friend gave it to me because he could not get it running and decided to buy a new tractor. Not a bad deal now that it is running.
/ satoh beaver #7
The counter clockwise pto is not bad, its just that most everything else turns clockwise as do most pto driven implements. If you need to buy a tiller for example, it may be hard to find one that will run backwards. Sounds like you got a good deal but do not ever, ever use starting fluid on this tractor. The piston tops are very thin and although many diesels were designed to be assisted by ether, this is not one of them. Go to the satohparts.com website and look at photos of what happens when ether is used. If your engine won't start using the glow plugs you may have a compression issue.
/ satoh beaver #8
Dont sweat the backwards Pto rotation. I have a little Beaver with the backwards pto(and the odd sized shaft), and I fixed it pretty quick and cheap. Want to know how?:eek:
/ satoh beaver #9
I would be interested in knowing how the PTO can be reversed on my Beaver for cheap.
I have already purchased the tractor and now I seem to be in a little bit of a bind.
Thanks!!!
/ satoh beaver #10
ok r we going to hear this cheap pto fix?:confused:
/ satoh beaver #11
Whoops, forgot about the post! Hate to keep everybody in suspense so long. You only need 1 part, available almost everywhere. The part is the pto adapter from 1-1/8" (old tractor) to 1-3/8 (standard). I think I had to turn the inside diameter out just a little to make it fit (about 1 hr of machinist's time if you don't have a lathe). You put the adapted part on the pto shaft, and attach it with a 1/4 or 5/16th inch bolt, that acts like a shear pin. You will have to cut your drive lines about 6" shorter than standard, as the adapter moves the shaft out about 6". Now for the fun part- how do you change the direction?? You don't. Suppose you were adapting this tractor to a funnel type fertilizer spreader. You don't adapt the tractor, you unbolt the spreader fins, and re-attach them backwards- fertilizer doesn't care whether its thrown left or right! Got a tiller to adapt? Same principle applies, swap the left facing tines to the opposite side, and vice-versa. Mower? Old Woods model RM 59, Swisher 40 " trailmower, and others have left handed blades. If life gives you lemons...find someone that life has given vodka, invite her over and have a party! (with apologies to Ron White for the stolen quote!)Dave:D :D
/ satoh beaver #12
well that solves that problem.nice solution.however some guys may not want to tinker with their attachments for those get a tractor with clockwise pto.
/ satoh beaver #13
It is fine if you have the pto attachments that you need for it.
/ satoh beaver #14
Several years ago I bought a used Woods RM48. It was made for a backwards PTO tractor. I bought a new set of blades that were correct rotation and the center bolts would not stay in. Fortunately I had a set of correct spindles to swap out. The center bolt on the backwards Woods is right hand thread. On a standard Woods the center bolt is left hand thread.
/ satoh beaver #15
Chain drive tillers do not like to run backwards,tensoner is own the wrong side.
/ satoh beaver #16
Forgot to mention that bit about the tiller and the chain tensioner. For the record, I haven't done a tiller, but I have converted the fertilizer spreader, and it works well. If I were doing a tiller, I would reverse the chain tensioner, or make one out of a block of black locust.:p
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
2005 Ford F-350 Stakebody Flatbed Truck w/ Liftgate (A61573)
2005 Ford F-350...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
