SAME Solaris 35 and 45 Heating problem
/ SAME Solaris 35 and 45 Heating problem #1
jjaime
Solaris 35 solaris 45
I have a year 2003 SAME SOLARIS 45 tractor.
It had problems of overheating and other problems related.
The tractor had been in garages, analyzed by mechanicals, but they did not find the solution.
Same neither provided any help.
So, I deeply studied the problem, made tests, and found the solution
The solution is simple, doesn't require technical works.
Anyone can do it.
Well, I spent time and money to find the solution.
If you give me money, I can tell you the solution.
I'm an Engineer, but not a mechanical Engineer.
This is honest.
Jacinto Neves
jneves80@yahoo.com
/ SAME Solaris 35 and 45 Heating problem #2
Those tractors when they switched from air cooled engines to water cooled ones, used a radiator where the fins in the radiator core are too tight, not allowing a good air flow through it.
It doesn't help that the fuel tank is in front of the radiator too, blocking a good amount of airflow.
This is a common issue with these models, that also affect the Lamborghini and Deutz models since those are the same tractors with different paint.
The fix is to have a radiator made where the core has the fins more open to allow more air flow, along with changing the fan to one that pulls the air from the radiator. Lots of people done it here in Portugal.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2006 Freightliner M2 Bucket Truck (A60352)
2006 Freightliner...
John Deere 50 (A60462)
2019 F150 (A61306)
2019 F150 (A61306)
