Saftey Switch
/ Saftey Switch #1
Fishcutter
Bluegrass State
John Deere L110
I have a John Deere L110 Lawn Tractor. I'm not getting fire to the spark plug. I suspect one of the safety switches (seat, clutch or blade engage). There are 4 wires to the seat switch. How can I test this switch (or others) to see if it is the problem?
/ Saftey Switch
/ Saftey Switch #3
First most mowers do not require the seat switch when starting.as you can start them by pushing the brake/clutch pedal while next to the machine. usually it's the Blade or brake/clutch switch that prevents starting. Lookat those switches first.Move a lever and carefully listen for a click.They get out of adjustment or their levers get bent or if your prone to washing the machines they can get loaded with water.
/ Saftey Switch #4
/ Saftey Switch
There is a switch on the seat, which prevents starting, as I have encountered on most lawn tractors.
/ Saftey Switch
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
MASSAGE CHAIR (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
