Saftey Switch
/ Saftey Switch #1
Fishcutter
Bluegrass State
John Deere L110
I have a John Deere L110 Lawn Tractor. I'm not getting fire to the spark plug. I suspect one of the safety switches (seat, clutch or blade engage). There are 4 wires to the seat switch. How can I test this switch (or others) to see if it is the problem?
/ Saftey Switch
/ Saftey Switch #3
First most mowers do not require the seat switch when starting.as you can start them by pushing the brake/clutch pedal while next to the machine. usually it's the Blade or brake/clutch switch that prevents starting. Lookat those switches first.Move a lever and carefully listen for a click.They get out of adjustment or their levers get bent or if your prone to washing the machines they can get loaded with water.
/ Saftey Switch #4
/ Saftey Switch
There is a switch on the seat, which prevents starting, as I have encountered on most lawn tractors.
/ Saftey Switch
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A61165)
2011 Ford F-350...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A61567)
2025 JMR Single...
Approximately 100 Ratchet Tie Downs (A61166)
Approximately 100...
2017 Dodge Grand Caravan Van (A61569)
2017 Dodge Grand...
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
