Saftey Switch
/ Saftey Switch #1
Fishcutter
Bluegrass State
John Deere L110
I have a John Deere L110 Lawn Tractor. I'm not getting fire to the spark plug. I suspect one of the safety switches (seat, clutch or blade engage). There are 4 wires to the seat switch. How can I test this switch (or others) to see if it is the problem?
/ Saftey Switch
/ Saftey Switch #3
First most mowers do not require the seat switch when starting.as you can start them by pushing the brake/clutch pedal while next to the machine. usually it's the Blade or brake/clutch switch that prevents starting. Lookat those switches first.Move a lever and carefully listen for a click.They get out of adjustment or their levers get bent or if your prone to washing the machines they can get loaded with water.
/ Saftey Switch #4
/ Saftey Switch
There is a switch on the seat, which prevents starting, as I have encountered on most lawn tractors.
/ Saftey Switch
LOT OF (3) DUPLEX PUMPS (A60736)
LOT OF (3) DUPLEX...
832757 (A61166)
832757 (A61166)
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
LOAD OUT AND SHIPPING (A61166)
LOAD OUT AND...
2844 (A58376)
2844 (A58376)
