Saftey Switch
/ Saftey Switch #1
Fishcutter
Bluegrass State
John Deere L110
I have a John Deere L110 Lawn Tractor. I'm not getting fire to the spark plug. I suspect one of the safety switches (seat, clutch or blade engage). There are 4 wires to the seat switch. How can I test this switch (or others) to see if it is the problem?
/ Saftey Switch
/ Saftey Switch #3
First most mowers do not require the seat switch when starting.as you can start them by pushing the brake/clutch pedal while next to the machine. usually it's the Blade or brake/clutch switch that prevents starting. Lookat those switches first.Move a lever and carefully listen for a click.They get out of adjustment or their levers get bent or if your prone to washing the machines they can get loaded with water.
/ Saftey Switch #4
/ Saftey Switch
There is a switch on the seat, which prevents starting, as I have encountered on most lawn tractors.
/ Saftey Switch
50 Gallon Fuel Cell with Pump (A61166)
50 Gallon Fuel...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
Toro Reelmaster 6500 D (A61166)
Toro Reelmaster...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
