Saftey Switch
/ Saftey Switch #1
Fishcutter
Bluegrass State
John Deere L110
I have a John Deere L110 Lawn Tractor. I'm not getting fire to the spark plug. I suspect one of the safety switches (seat, clutch or blade engage). There are 4 wires to the seat switch. How can I test this switch (or others) to see if it is the problem?
/ Saftey Switch
/ Saftey Switch #3
First most mowers do not require the seat switch when starting.as you can start them by pushing the brake/clutch pedal while next to the machine. usually it's the Blade or brake/clutch switch that prevents starting. Lookat those switches first.Move a lever and carefully listen for a click.They get out of adjustment or their levers get bent or if your prone to washing the machines they can get loaded with water.
/ Saftey Switch #4
/ Saftey Switch
There is a switch on the seat, which prevents starting, as I have encountered on most lawn tractors.
/ Saftey Switch
832721 (A61166)
832721 (A61166)
TEREX TH8440 TELEHANDLER (A60736)
TEREX TH8440...
832625 (A61166)
832625 (A61166)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A61165)
2011 Ford F-350...
Transfer tank (A61567)
