Safety Tips For Beginners
/ Safety Tips For Beginners #41
Loved your book and can’t wait for the sequel. However on the Kioti CK10 series the linked pedal is not associated with an advanced hydrostat at all. All it does is throttle up the rpms of the engine as you push the pedal. The hydrostat is the same as the tractors without linked pedal. There are similarities I suppose but in the end it is just the same as throttling up and down manually as you manipulate the hydrostat, rather than changing the hydrostatic function itself.
yes, I am aware of those also. All kinds of advancements have been made and new features offered since Kubota came out with HST+. All manufactures are playing catch up ball and want to offer some of these things. The linked pedal is the simplest of features to offer. A few guys have made their own "linked pedal" linkage. Load match and Stall Guard may be trademarked names of of John Deere features as well as E-Hydro.
Oh,.. as for the sequel to "the book", I have writers cramp now.. :)
/ Safety Tips For Beginners #42
Many issues have occured when you box yourself in or don't give yourself enough room. Go up against a rock, building or tree and it's like you get sucked in and need additional equipment to get free without damaging anything.
Same with water and a slope. Go too close and you WILL get sucked in!
Are you saying if you mow around your pond long enough, your tractor is going to be in the water? :)
/ Safety Tips For Beginners #43
It would seem so.
/ Safety Tips For Beginners #45
Hmm, on Kubota the more you push down the less torque but more speed, never measured fuel.
Auto Throttle advance. As you press the HST peddle. It gives it more fuel.
/ Safety Tips For Beginners #46
So as can be evidenced by the preceding discussions; being aware of your own equipment design & limitations and the manufacturer's recommendations can be important as not all things are made the same way between different manufacturer's (even if they look very much alike).
Another illustration of that point is with grapples: Artillian doesn't recommend pushing on something with their sectional grapple lid closed, where as on some of the Everything Attachment grapples (particularly those where the lid can close and rest on the lower tines) having the grapple lid closed in order to push on an object was the recommendation made in (at least some of) their videos.
Two relatively similar implements from two different manufacturers with recommendations that are completely opposed to each other based on how each designed their own product.
Of course as always, the recommendations of others are no replacement for actually thinking through and properly evaluating what it is you're trying to do on any given task.
A major part of my work involves safety/regulatory/design reviews, and there have been more than a few times I've come across situations (or even mishaps) where the individual(s) involved (to include the designing engineers) followed "standard procedures" and it resulted in a negative outcome because the situation either wasn't covered, or it was a corner case where blindly following the procedure/regulation would actual result in bad outcome.
Now don't get me wrong as I think learning from others is a very good thing -- it just has to be appropriate for and applicable to the specific situation.
The other thing is keep an awareness of your surroundings as you work as the environment can change ---- and while tractors may not move all that fast, they typically don't stop all that fast either.
One last thing, changing the set-up of the tractor (e.g. which implements are attached) will change the handling and space required to maneuver...... I've clipped some of my fence lines a time or two, because I was mowing with the bucket attached rather than my usual practice of mowing without having on the FEL (thankfully it was all in low speed turns so it didn't cause much damage).
I really appreciate all the tips you guys provided. I am probably going to break it in Friday.
/ Safety Tips For Beginners #48
And keep in mind tractors can tear up a lot of property in a hurry. Around buildings, they can take the side out of your house with one wrong move, They excel in tearing out fence if you let them.
/ Safety Tips For Beginners #49
Take it slow. Learn your equipment, what it can and can't do. My dad, who grew up on tractors, was flying circles around me. Yet, his tractor was wider, lower center of gravity, and he had experience on it. I have been using mine for a few months now and becoming more comfortable and understanding how different things work. Still no where as comfortable as my dad, but I have taken it slow, learning what my tractor can and what I'm comfortable doing. The HST+ transmission has been a really a great feature which when I purchased the tractor I didn't realize how nice and useful that feature is to have on the tractor.
Again, my advice, go slow and don't exceed your comfort level.
/ Safety Tips For Beginners #50
Many people don't. And many see the extra money you have to spend from a Standard L to a Grand L as wasted. They literally don't understand what they are missing. They can see the extra weight in the machine, but often don't understand the significance of that, and they can visually see some of the convenience features that will make using the tractor so much more productive, but will often use derogatory language like "bells and whistles" never seeing that over the lifetime of the tractor, the extra productivity and lessened operator fatigue will more than make up for the extra money spent upon purchase. And then there are the features that are not so easy to see like HST+. Many will think it is all just "advertising" or a "gimmick". It isn't.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
MASSEY FERGUSON DL250 FRONT LOADER (A59823)
MASSEY FERGUSON...
2013 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2013 BIG TEX 20...
DEUTZ MARATHON...
New/Unused Electric Golf Cart (A61166)
New/Unused...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
