Safety Tips For Beginners
/ Safety Tips For Beginners
Lets go over some basics of engine, Ordinary hydrostat (there are hydro's that are NOT ordinary) range shifter, and final drive gears.
Think of the engine as more like a stationary engine that runs at what ever rpm you set it at and a governor assembly that tries to keep it at that rpm as the load increases. This is unlike an automotive engine that you are constantly changing the rpm and torque output.
The ordinary HST is a variable displacement pump, that is fastened directly to the engine output shaft of the engine, sometimes with a dry clutch in some models, and No clutch in many models. Attached to the variable displacement pump via oil passages or in a few machines by oil hoses is a fixed displacement hydraulic motor. Yes there is a few with variable displacement, but they are NOT the ordinary HST's I am talking about here.
The variable displacement hydraulic pump is controlled either directly by the "go pedals/pedal" or thru a hydraulic servo in some models. But many in this size class have just direct connection to the inside of the pumps "swashplate" The swash plate is on a pivot that the pedal controls the angle of the pivot action of the swashplate. (those of you with helicopter experience are now saying "swashplate", I know what that is!". riding on that swash plate are usually 9 "slippers" that are fastened to pistons. The angle of the swash plate determines the flow rate of the fluid out of the motor thru the passages and on to the hydraulic motor. As the pistons and slippers rotate around the "suck" fluid from the return and push it out the forward ports as they come around to them. Unless the swash plate angle is zero. Then no fluid flows or if the swash plate move the other direction the fluid moves the other direction to the ports and the tractor goes in reverse. So Zero angle = neutral, no movement, forward angle = flow to forward ports and hydraulic motor moves forward and backward angle the flow goes the other way and tractor goes the other direction. The tractors (like mine) with with hydraulic assist do the same thing only it give you some hydraulic assist to move the swash plate so you foot doesn't have to do all the work of applying pressure to it all the time. and of course "cruise control" figures in here also if your tractor has that feature. Some do some don't.
So let's go over what we have so far. Engine, is the prime mover, usually run at a fixed RPM, and maybe a clutch or NOT, and a variable displacement pump under control of the operator by the pedal system controlling the swash plate angle, followed by a powerful hydraulic motor able to go either direction depending on the ports the oil flows into from the pump. There is NO mechanical connection between the engine and the pump. Just a hydraulic one. Now. on to the Range transmission.
The range transmission is either a two or 3 gear ranges ordinary old non synchronized transmission. Nothing fancy here. Just 1890's technology here. The power comes out of the range transmission on to the final reduction drives and power is tapped off here for the front differential propeller shaft for 4WD with a shifter of course to engage this, either direct mechanical or electric over hydraulic shifter.
So here is what happens when you "attack" a hill in let's say HI range on your range shifter and your tractor has a big load in its loader bucket. The power needed to get up the hill is great, the puny engines RPM is starting to fall because of this load. Your first impulse of what you have done all of your life is "stomp on that accelerator pedal to make more power . Only it just makes things worse. your tractor bogs down even more. Here is why. When you increase the angle of the swash plate, you are making MORE oil flow from the pump headed to the motor, which puts even MORE load on the prime mover, the engine. You are calling for more speed, but speed is not what you need, you need more torque. If you cannot get any more torque from the engine by the fixed throttle and the governor has already tried to maintain the RPM level and can do no more then the RPM's are going to fall, the engine is going to fall out of its "torque curve" sweet spot, and you are not going to go up that hill any faster, or maybe not at all. What could happen is that the pressure builds in the pump to the point even that the pumps relief valve opens or starts to. We are talking about pressures around 5000 lbs per square inch here or more.
BUT if we let off of the swash plate, we reduce the flow rate and we slow down, we lower the pressure but we also give the engine a little breather and remove some of its load and possibly let the RPM's stabilize or even go up a bit and get closer to the torque/RPM curve that the engine wants to operate in. NOW to be honest, you should not have been a darn fool and attacked that hill in HI range anyway with it taller gearing. You should have looked at that hill at the bottom and said "I am heavily loaded, and I better downshift the range selector to M or even LO if it is really really steep.". But you got to make that determination "before" you attack. You cannot "shift on the fly, and to swap those gears on a hill is a dangerous proposition. You better be riding those brakes, and you better be in 4WD as you come to a stop, you will have to mesh that old coffee grinder transmission gears while trying to keep the tractor from rolling backwards downhill. Use caution.
Yes, for those of you with some advanced hydrostats, are chomping at the bit about your 2 speed variable displacement hydraulic motors. Keep chomping because this "book" is about ordinary hydro's, :) Not advanced hydro's with really cool features. You have to pay actual good money for those "bells and whistles" that many think they don't need.
So you have to have some "smarts" before you are in trouble climbing that hill. But stomping the forward pedal is NOT the answer. Notice I said you had a puny engine. Yes it is very puny. Mine has around 35 horsepower and my tractor fully ballasted with loader attached is over 6000 lbs. without a load in the bucket. So think about that a bit. How many cars weight 6000 lbs. Not too many nowadays. How many cars have 35 hp or so engines? Not too many. Tractors are all about gear reduction to increase torque, and they don't need to go real fast, they have lots of torque to pull, and low speeds, but there is a limit if you gear it too high. Think ahead. We tend to "load up" out tractors with liquid filled tires or wheel weights, and lots of rear ballast not to mention the payload we put in the bucket or grapple, but the engines just aren't that big for the most part.
I hope this "book" has helped a little bit, if not, well, I was just watching TV over the laptop anyway. :)
Thanks for the detailed summary. I think I get it. I am curious about something. As I was demoing the tractor, I was going easy on the gas (forward hydro pedal) and he told me not to do that. Can you think of any reason I shouldn't go easy on the hydro pedal?
/ Safety Tips For Beginners #22
No, i cannot. You can use the hydro pedal at any speed/torque you desire. When you let off you are in "neutral" the swash plate angle is zero degrees and no oil (or verly little) is flowing. I don't see a problem with that. You often need to creep around when working to be safe. Remember HI range is ONLY for road transport on relatively flat roads. Med is for common work tasks to be able to still run relatively fast but has good torque. LO is for the most torque (like pushing or pulling something heavy) and the least speed. If your tractor will only have two ranges, then Low for work, and HI for transport on the road. 3 speeds are better than two.
/ Safety Tips For Beginners #23
From a newbie myself. Watch the Ask Tractor Mike YouTube videos, especially the safety ones. Subscribe as well.
Lower your center of balance by loading your tires, add wheel weights, and/or a rear ballast weight. I really feel the positive affect of my new homemade concrete ballast. Read up on rear tire pressure recommendations.
I have started working on a sloped wooded area and I raked the area I plan to cross (vs up/down travel) clearing limbs, ferns, ground cover looking for drop outs and boulders. Clearly this is only feasible working in a smaler area. I measured the various slope angles to get a sense of what 10 vs 15 or 20 degrees looks like. No, I do not yet know what feels safe other than less than 10deg.
Treat your tractor like a chainsaw - firm grip, don't extend, never rush, quit when tired.
/ Safety Tips For Beginners #24
Safety tips
If it LOOKS right, It probably is right.
If it FEELS wrong, It probably is wrong.
Trust, but verify! DO THE MATH when lifting stuff. 5 to 1 safety factor is NOT generous. It's good sense.
/ Safety Tips For Beginners #25
That's where the confusion comes in. It isn't a gas (diesel) pedal. Fuel is controlled by a lever up near the steering wheel. That thing on the floor is more like the "gear selector" on an automatic transmission.
Bruce
/ Safety Tips For Beginners #26
A lot of farm accidents involve the PTO. Do yourself a favour and turn the tractor OFF when working around the PTO.
/ Safety Tips For Beginners #27
Bruce
Exactly and what really is hard to get used is when you go up hill and are slowing down let up on the HST pedal so the tractor will be in a lower gear.
The tendency is always to "give it more gas with your foot" but the throttle is your hand.
/ Safety Tips For Beginners #28
All good replies.
I am new too...nearly got crushed between a tiller and the tractor when I was helping a guy. DO NOT work on a tractor that is running with someone in the seat.
If you have a bushhog. do not operate it within 50 ft of anything you do not want hit with a rock. It will leave a mark...or worse.
/ Safety Tips For Beginners #29
On your car, when you need more power, you push down a bit on the pedal.
On your tractor, when you need more power, you let up a bit on the pedal.
The HST pedal manages the transmission, not the fuel delivery. Down is "high gear" and up is "low gear."
Bruce
I have HST+ the more you push the hydro the more fuel.
/ Safety Tips For Beginners #30
Hmm, on Kubota the more you push down the less torque but more speed, never measured fuel.
/ Safety Tips For Beginners #31
What he is referring to here is what some other manufactures call "linked pedal". Remember those Other more advanced Hydrostatic transmissions I referenced? Well that is one o the other functions of this advanced hydro. Linked pedal. Kubota doesn't call it that as I remember, but the concept is the same.
/ Safety Tips For Beginners #32
Hmm, on Kubota the morning you push down the less torque but more speed, never measured fuel.
BUT, you must remember the "more advanced hydros I mentioned in my "book". HST+.. Note the "plus". there are lots of advanced features with this hydro.
/ Safety Tips For Beginners #33
k0ua you mention, "If you live in Kansas with no hills in sight, then these things become less important. But keep them in the back of your mind."
The mental picture may be it's all flat land, but even then there are unforeseen holes a tire can fall into. How about pond dams, road ditches, any slopes at all can cause one to be caught off guard. And another thing to be cautious of is when working around trees, be sure all limbs are higher than the ROPS. You snag a good size limb with the top of your ROPS and you'll instantly be riding a bucking bronco!
/ Safety Tips For Beginners #34
Absolutely. I was just using Kansas, because people think of Kansas as flat. Of course it isn't all flat, and as you mention there are plenty of other things that can throw you for a loop. Yep a big limb on your ROPS will likely wake you up pretty quick. :) Garage overhead can do it too.. Tractors like any other kind of dangerous machinery require vigilance all the time. Others have mentioned PTO safety. Just one of the many ways you can get into trouble around a tractor. Pinholes in hydraulic hoses and the risk in hydraulic fluid injection is another. If anyone doesn't understand this, I can show you some pictures. I will warn you they are not pretty.
/ Safety Tips For Beginners #35
We had a tractor operator preventable accident a few years back. The operator was bush hogging and ran over some hidden wire. He did not have chains on the mower or a protective shield on his tractor. A piece of wire was thrown into the back of his head and they found him dead on the tractor going in circles.
/ Safety Tips For Beginners #36
Freakish! How did a projectile achieve that trajectory? Usually, the mower is too close to the tractor.
/ Safety Tips For Beginners #37
Many issues have occured when you box yourself in or don't give yourself enough room. Go up against a rock, building or tree and it's like you get sucked in and need additional equipment to get free without damaging anything.
Same with water and a slope. Go too close and you WILL get sucked in!
/ Safety Tips For Beginners #38
Loved your book and can’t wait for the sequel. However on the Kioti CK10 series the linked pedal is not associated with an advanced hydrostat at all. All it does is throttle up the rpms of the engine as you push the pedal. The hydrostat is the same as the tractors without linked pedal. There are similarities I suppose but in the end it is just the same as throttling up and down manually as you manipulate the hydrostat, rather than changing the hydrostatic function itself.
/ Safety Tips For Beginners #39
I love my wheel loader with the throttle pedal operating the hydrostat. And a left hand F N R lever on the steering sheel. BUT, it would be somewhat useless for PTO operation which mine of course does not have.
/ Safety Tips For Beginners #40
If you have doubts don't try it.
John Deere 6300 (A60462)
John Deere 6300...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
