Sabre Samurai on Kubota B2320
/ Sabre Samurai on Kubota B2320 #1
Owlpond
Clifton Springs
Kubota B2320
Hi All,
New guy here hoping for some advice. I have a Kubota B2320 with backhoe and loader. Just purchased the Sabre Samurai sickle bar cutter. I incorrectly assumed I could run this thing off the backhoe attachment but when I plumb the lines to it it doesn't work. I assumed the backhoe line when not used loops back on itself, with one side being pressurized and the other a return? Thanks in advance for any help.
/ Sabre Samurai on Kubota B2320 #2
That line will have full pump flow provided the loader valve and 3pt are not activated but without a control valve with power beyond I wouldn't recommend hooking to it if you're using the 3pt.
2009 Ford Ranger 4x4 Ext. Cab Pickup Truck (A59230)
2009 Ford Ranger...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
4 ROW CULTIVATOR FRAME (A60430)
4 ROW CULTIVATOR...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
4021 (A59228)
4021 (A59228)
