SA424 Will not move forward or reverse.
/ SA424 Will not move forward or reverse. #1
JJRODD
2014 Yanmar SA424
2014 SA424, exited the tractor with the engine running I didn't set parking brake. The tractor shut down as expected. Once I started the tractor it will not go forward or reverse. Front loader and 3 point works fine. Hydraulic fluid is in the center of the sight window. Any ideas?
/ SA424 Will not move forward or reverse. #2
Winston said. (y)
/ SA424 Will not move forward or reverse. #3
When you push on the pedal do you hear the hydro trying to move the tractor? Are you certain that the brake is disengaged. Mine has stuck before, a couple times, and it would not go anywhere. Have to push down on it a little harder to get it disengaged.
/ SA424 Will not move forward or reverse. #4
If all the linkage is working and moving properly. Hyd. Trans. etc..
  • Cast iron transmission and front axle and dual hydraulic pump
  • Two side-by-side hydrostatic transmission pedals Full-frame chassis
/ SA424 Will not move forward or reverse. #5
JJRodd, Have you repaired the tractor
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
2013 CHEVROLET 2500 HD (INOPERABLE) (A63569)
2013 CHEVROLET...
2011 Bobcat T650 Compact Track Loader (A64047)
2011 Bobcat T650...
