SA424 Will not move forward or reverse.
/ SA424 Will not move forward or reverse. #1
JJRODD
2014 Yanmar SA424
2014 SA424, exited the tractor with the engine running I didn't set parking brake. The tractor shut down as expected. Once I started the tractor it will not go forward or reverse. Front loader and 3 point works fine. Hydraulic fluid is in the center of the sight window. Any ideas?
/ SA424 Will not move forward or reverse. #2
Winston said. (y)
/ SA424 Will not move forward or reverse. #3
When you push on the pedal do you hear the hydro trying to move the tractor? Are you certain that the brake is disengaged. Mine has stuck before, a couple times, and it would not go anywhere. Have to push down on it a little harder to get it disengaged.
/ SA424 Will not move forward or reverse. #4
If all the linkage is working and moving properly. Hyd. Trans. etc..
  • Cast iron transmission and front axle and dual hydraulic pump
  • Two side-by-side hydrostatic transmission pedals Full-frame chassis
/ SA424 Will not move forward or reverse. #5
JJRodd, Have you repaired the tractor
2014 STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
2014 STARCRAFT...
2024 SILVERBACK 53XH3A 53FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
2012 HAULMARK ENCLOSED TRAILER (A63569)
2012 HAULMARK...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
