SA424 Will not move forward or reverse.
/ SA424 Will not move forward or reverse. #1
JJRODD
2014 Yanmar SA424
2014 SA424, exited the tractor with the engine running I didn't set parking brake. The tractor shut down as expected. Once I started the tractor it will not go forward or reverse. Front loader and 3 point works fine. Hydraulic fluid is in the center of the sight window. Any ideas?
/ SA424 Will not move forward or reverse. #2
Winston said. (y)
/ SA424 Will not move forward or reverse. #3
When you push on the pedal do you hear the hydro trying to move the tractor? Are you certain that the brake is disengaged. Mine has stuck before, a couple times, and it would not go anywhere. Have to push down on it a little harder to get it disengaged.
/ SA424 Will not move forward or reverse. #4
If all the linkage is working and moving properly. Hyd. Trans. etc..
  • Cast iron transmission and front axle and dual hydraulic pump
  • Two side-by-side hydrostatic transmission pedals Full-frame chassis
/ SA424 Will not move forward or reverse. #5
JJRodd, Have you repaired the tractor
Case skid steer wheels and tires (A63689)
Case skid steer...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
John Deere 2680H (A64126)
John Deere 2680H...
