RX7320 Fuel Sending Unit (Crud)
   / RX7320 Fuel Sending Unit (Crud) #1
FairWeatherFarmer
RX7320
I have had fuel level issues with my 2022 Kioti RX7320. Tested the electrical to the sending unit and all was ok. Finally pulled the sending unit and found all kinds of crud on the sending unit. Has anyone else experienced this issue? Have always used fresh filtered fuel and the tractor is kept in shed when not in use. It is stuck to the bracket, but is not rust at least from the bracket.
   / RX7320 Fuel Sending Unit (Crud) #2
What fuel additives are you using, if any? You might need to add a biocide at least…
  • Good Post
Reactions: J&K
   / RX7320 Fuel Sending Unit (Crud) #3
I not had any problem with mine so far. Like mentioned above might us some Biocide once in awhile. I add in the winter if we don't get much snow and it sits.
   / RX7320 Fuel Sending Unit (Crud) #4
Just remember that biocide kills the (microbes)bug….but doesn’t clean the fuel system. That’s the big part of the job. Draining/flushing the complete system and multiple filter changes. Best to prevent the problem in the first place 😉
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
