RX 75 problem
/ RX 75 problem #1
mns
Bought my Dad a RX75 that he used on a small lot a few times. Suddenly it quit moving (forward or backward). The motor, belts, and pulleys look fine. I believe something went out in the axle. Any help or suggestions would be appreciated. Is their parts available? Thanks
/ RX 75 problem #2
I bought one last year for Nancy. Great little machine she runs it all over, better then a lawn tractor for mowing.
Here's the story. I got it from a guy who said the tranny was bad. Sure enough I can't move it. Pulled the back wheels and found one side had a key on the shaft missing from when someone changed a flat tire.(It must have slipped out) Put in a new key and away she went!
Rob
/ RX 75 problem
I'll check it. We did put a tube in the rear before it went out. Thanks
/ RX 75 problem #4
are you sure you checked all 3 belts. there are 2 traction drive belts tucked and hidden away between the frame members. not calling you stupid, most people don't realize there are 3 belts.
/ RX 75 problem #5
It's easy for the pin to fall out and for you not to notice it when putting the tire back on. Also check BOTH sides.
Sometimes times the wheel is tight when you put it back on so the tranny runs fine for awhile.
best,
Rob
/ RX 75 problem
It was the key in the left rear wheel. Thanks
2008 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65056)
2008 GENIE Z-45/25...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2020 CATERPILLAR D6XE LGP HIGH TRACK CRAWLER (A65056)
2020 CATERPILLAR...
2023 Unused Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
2023 Unused Monroe...
2020 AUTOCAR XSPOTTER TRUCK (A65057)
2020 AUTOCAR...
Kaufman 47ft. Gooseneck Tri Axle Car Hauler Trailer (A66736)
Kaufman 47ft...
