Running Tractor without Side PAnels Installed
/ Running Tractor without Side PAnels Installed #1
RickDpwv
Princeton, WV
Rural King RK24H
Been doing a lot of brush hogging with the RK24 in temperatures around 90 F. I Get a lot of heat from the motor back on my legs. Was wondering if it would hurt the tractor (effect the efficiency of cooling of the motor) if I ran it with the side engine covers removed. It makes a big difference on the amount of hot air put back on the operator and I would think having the air flow unrestricted around the motor might even make it run cooler. No way to tell since there is no temperature gauge. What do you guys think??
/ Running Tractor without Side PAnels Installed #2
I think if your cooling system is functioning properly - it should be OK to remove the side panels.
/ Running Tractor without Side PAnels Installed #3
Think they're on there to keep the larger stuff out.
And to make them look pretty.. ;)
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2021 Kawasaki Teryx KRX 1000 SE (A62679)
2021 Kawasaki...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2022 EZ-GO ELITE...
