Run-a way engine mahindra 1626 hst
   / Run-a way engine mahindra 1626 hst #1
David Shepard
Mahindra 1626 HST
While at idle, the engine goes into a "run-a-way" situation. I can turn the key off and it shuts off the engine. when I restart the engine everything seems fine for s short time then run-away engine again. Is there an "idle brain" component in the system?
   / Run-a way engine mahindra 1626 hst #2
It really depends on what fuel system and injection pump u have.
Are u sure it’s not just going into regen mode.??
   / Run-a way engine mahindra 1626 hst #3
Unless you have an oil or fuel leak it’s probably an issue with the governor.
   / Run-a way engine mahindra 1626 hst #4
If it has a PFR injection pump, they’re known to shear the teeth on the gears inside the pump.. causing a no start condition OR a run away..
Do a search for PFR injection pump.. and see if it matches your inj pump..
If yes, there is a tutorial on this site that someone posted when they did theirs.
2008 Keystone Camper Mod. 311BHS (A59814)
2008 Keystone...
More info coming soon! (A56859)
More info coming...
Miller Bobcat 250 Diesel Welder (A57453)
Miller Bobcat 250...
2020 MACK P164T (A58214)
2020 MACK P164T...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
HUSQVARNA RIDING...
