Run-a way engine mahindra 1626 hst
   / Run-a way engine mahindra 1626 hst #1
David Shepard
Mahindra 1626 HST
While at idle, the engine goes into a "run-a-way" situation. I can turn the key off and it shuts off the engine. when I restart the engine everything seems fine for s short time then run-away engine again. Is there an "idle brain" component in the system?
   / Run-a way engine mahindra 1626 hst #2
It really depends on what fuel system and injection pump u have.
Are u sure it’s not just going into regen mode.??
   / Run-a way engine mahindra 1626 hst #3
Unless you have an oil or fuel leak it’s probably an issue with the governor.
   / Run-a way engine mahindra 1626 hst #4
If it has a PFR injection pump, they’re known to shear the teeth on the gears inside the pump.. causing a no start condition OR a run away..
Do a search for PFR injection pump.. and see if it matches your inj pump..
If yes, there is a tutorial on this site that someone posted when they did theirs.
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59575)
2004 INTERNATIONAL...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
