RTV OR COMPACT TRACTOR PLOW
   / RTV OR COMPACT TRACTOR PLOW #1
eyi
quebec
Kubota L3800
Hi all,
I am a glad owner of both a Kubota RTV 900 and L3800 and I live in Canada, just north of Maine’s border where there is plenty of snow.
I feel as if my snow removal setup is not optimal. Actually I always use the tractor to remove snow, either with the back snowblower and a back plow. The problem is I like to do plenty of logging in the winter so my logging winch has to be on the tractor and I am tired to remove it each time I need to take care of snow.
I have a 1500 feet road to be taken care of as well as the perimeter of our cottage, garage and sugarshack, you see the setup…
My question is should I go with a plow on the RTV or a quick attached front plow on the tractor FEL ??
Thank you very much
   / RTV OR COMPACT TRACTOR PLOW #2
I have a full sized tractor and an ATV snow plow;given a choice I would go with the tractor(FEL mounted 8'),ATV is a lot smaller but fits in the tight spots.
Tractor also has a 7' rear blade.
   / RTV OR COMPACT TRACTOR PLOW #3
I've never used an ATV, but I do like my ssqa tractor plow. My tractor use is 100% snow duty during the winter so I do very little switching of implements, other than the rare swap of the rear 7' blade with a 6' blower.
   / RTV OR COMPACT TRACTOR PLOW #4
RTV with heated cab sounds pretty nice for 1500' drive in Canada.
   / RTV OR COMPACT TRACTOR PLOW #5
I use both. I have an open station tractor with a rear blower and an RTV-X1100C with a 6-1/2 foot Boss vee plow.
Like Yander said, the heated RTV cab is wonderful when it's minus 40 and the wind is howling. My tractors are all open station and I use a rear blower because I use my loader daily.
The RTV will push lots and has good traction. But you have to remember, with a plow you need to get out when it is storming and not let it build up too much. A plow won't eat through feet of snow like a blower will.
And by the sounds of it, you with a 1500 foot drive to clear, an RTV with a plow should be okay because you have a nice long run to keep your speed up to throw the snow off the plow. And like I say if you don't let it build up too deep, the RTV is a lot faster than a tractor.
   / RTV OR COMPACT TRACTOR PLOW #6
I have the same setup, a good sized open tractor with a rear blower and a 1100C with a Vee plow. The tractor does the heavy/deep snow work, the RTV does the small storms after the ground is frozen. At 62 it's nice to have the heated cab. I could not do snow removal without the tractor, but did snow removal for 20+ years without the RTV. So if the question is "if I can only have one machine for snow removal?", the answer would be the tractor.
Thanks everyone for your answer. I forgot to mention both my RTV and tractor are open station .
   / RTV OR COMPACT TRACTOR PLOW #8
I agree. I got rid of my F550 truck and Boss vee plow because tractor even outperformed it DISCLAIMER: FOR MY APPLICATION LOL
   / RTV OR COMPACT TRACTOR PLOW #9
I kinda got off track now that I read your original question again. I would think the RTV would handle a plow better than one on the loader of a compact tractor? I feel as though a loader plow would try and steer you more than a plow on the RTV? And the RTV can travel at faster speed.
If those are your only options. But I would NEVER be without a tractor and blower.
   / RTV OR COMPACT TRACTOR PLOW #10
I have a Snowsport plow that I used on my TC33D tractor and on my RTV900. For most snows, I preferred to use the RTV over the tractor because of the speed. BUT, if we would get deep heavy snow (2ft+), then I could always put the plow on the tractor.
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A46683)
2025 78in Dual...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2015 PETERBILT 389 MID-ROOF SLEEPER (A48992)
2015 PETERBILT 389...
Location (A49339)
Location (A49339)
2022 Tong Potato De-Stoner/Clod Remover, (A47369)
2022 Tong Potato...
2020 John Deere 333G Track Skid Steer (A49339)
2020 John Deere...
