RTV losing power
/ RTV losing power #21
with a very heavy load I experience the same thing. I is best not to try to get off the line going straight up. Of course shifting is easier as well if one cuts across the pitch. I usually plan my wood runs to load as I descend. That way I can also load the bed with the logs on end which gives me a denser pack and a more stable load.
/ RTV losing power #22
Whoodle
It sounds like you have run into a similar circumstance.
It may be more favorable to climb the hill by not starting right at the bottom, but now I want to pursue this from a stop right at the bottom. Most comments indicate the RTV cannot be stopped. Maybe they aren't on a very steep hill or maybe they aren't carrying a load.
I am going to re-check the air cleaner and check the spark arrestor -never thought of that one. When I go to the dealer next Wednesday, I will have a payload of 1600#, as that is the max according to the manual. I will weigh a bundle of shingles and throw on just enough to bring the load to max.
Thanks, everyone, for all the good comments.
/ RTV losing power #23
Be careful going up steep slopes with an overloaded or fully loaded RTV. I was able to lift the front tires when I was hauling a full load of fill dirt up a steep slope.
The dirt was piled higher than the side rails, which raised the center of gravity. Keep the load low and seat belt fastened.
/ RTV losing power #24
Here's what happened at the dealer:
Dif lock hold down cable was adjusted and now works as it should. The new diesel tank was install and there is no leakage at the cap. Dealer installed a secound gasket on cap so that it doesn't have to be screwed down so many turns.
The power problem is a wait and see. They suggested I change to an after market air cleaner (K&N) for added air. I've also removed the spark arrestor for the winter.
The RTV will still not turn a wheel when fully loaded, with dif-lock and 4 wheel drive engaged, IF I try to start on a steep hill. Normally, I think it will be OK.
I still like the RTV. It has many advantages over the competetion for my use, a worker.
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
1999 INTERNATIONAL (INOPERABLE) 4900 (A67714)
1999 INTERNATIONAL...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
RANGER S/A TRAILER W/WELDER (A67714)
RANGER S/A TRAILER...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
