RTV in the mud
/ RTV in the mud #21
litework said:
I have owned and operated quads/UTVs in one form or another for 22 years. The UTV is the most utilitarian UTV I have ever driven. I never said the UTV wouldn't get stuck quicker than the others. I said that it was good enough to perform the OP's tasks without worrying about getting stuck. Simply put, the RTV does not get stuck easy. I think you, like many others, misinterpret the market Kubota is after with the RTV. This is evidenced by your listing of several very good sport side by sides, none of which have a diesel...except for the Mule; though I'm pretty sure the one you mentioned isn't the diesel version. The Kubota RTV is not a sport side by side.
Diesels are loud and expensive. Diesels are also meant to be driven all day long under load. The RTV is basically a tractor with a hydraulic bed. If you really want quiet, light and nimble and you want something to drive you to your barn or work vehicle...I think the EZ-Go electric is probably one of the better ones on the market.
I would say the only Sport side by side I mentioned is the Rhino, but we still use it all day to haul or pull loads, and carry work equipment with. We do not use it like you mentioned the Kubota is made for "to be driven all day long under load", but we do drive it to where work needs to be done, then load up and go to the next place.
I would also consider the Mule (gas or diesel) for work, not sport. They are similiar in speed to the UTV, not fast or sporty. Honestly, I don't like the Polaris because it is a Polaris. Other than that, it is great to work with. It is wider than the Rhino, but also offers more room in the bed. Yamaha is a great all around performer. It works as needed, runs a little faster than the Mule or RTV, but it is also great for just riding the trails. It is more versitile, but still has problems with CV boots and axles.
All points are good, and I enjoy reading all the input. But I still highly HIGHLY recommend testing the waters before diving in. Too bad dealers won't let you Demo most of these like you can equipment.
HAPPY THANKSGIVING
/ RTV in the mud #22
HAPPY THANKSGIVING
My wife and I looked at the Rhino first. There's a really good Yamaha dealership less than a mile away. We wanted more than 400lbs of cargo bed capacity. Ultimately, we had to prioritize and establish what was important to us.
Happy Thanksgiving to you and yours.
/ RTV in the mud #23
rutwad,
Yes, the answer to you question, if I have used or run / worked any others...
Your humble answer is YES, YES , YES, Heck, run 'em , we own them,
On the farms & plantations that we also own, which consist of 6,632 acres of farm land & Hardwoods !!! Rhinos, Mules, RTV's, and Honda Rubicons & Rincons. So not pickin' on your either, but wouldn't own another Ranger, purchased two at the same time, and both of them stayed in the shop, keep the Polaris' seven months and got rid of them. Waste of good money ......
Now, that being said, in my opinion, the other utility vehicles are good, my second pic is the Rhino. They give us good service for what they are used for.But the RTV, in our applications, is the better machine, not knocking others, but serves use very, very well !!!!! We work our machines, don't play with them.
Now, for your information, not only are we purchasing several more RTV's come Feb. or March, as soon as Honda releases the new utility vehicles, there will be two of them purchased also. And then , we will let you know how they work out on the working & farming operations.
Oh, let me not forget, we had two gators also, and they were good utility vehicles !!!
/ RTV in the mud
litework, Thanks, I'm putting more stock in the actual owners/users comments, although there are some without mentioning names, but he thinks his BX22 will out work a D11R Cat, I know how the hydro works and that it will stop short if you don't know how to let up on the pedal, and it won't pull if you try to climb in high gear, ie pedal all the way down, the hydro works like my tractor. I'm hoping it would do at least as well in the mud as my BX 2200 and have more ground clerance, I have a down hill drive way and a really steep long road going down to the creek so I need the hold back with the hydro. I still hate dropping the cash without seeing one work right here.
/ RTV in the mud
TWO GUNS, I was typeing the same time you were, didn't realize you had actually owned/used all those other machines, and you have enough ground to find out what they're made of. I know it is different to go and sit in one and drive around the lot and actually work one. I have a good friend that has a UTV and he thinks it is the all purpose do all wonder, I've used it, tried it over and over, cannot make myself like it, but they've sold a gazillion of them so it must fit a lot of people.
I'd like to see some of the mud you've been through, that swamp stuff has no bottom.
/ RTV in the mud #26
milkman said:
... I know how the hydro works and that it will stop short if you don't know how to let up on the pedal, and it won't pull if you try to climb in high gear, ie pedal all the way down, the hydro works like my tractor. ...
milkman, I think you hit the nail on the head here. We are accustomed to pushing an accelerator pedal down when we need more power going up a hill. Exactly the wrong reaction with a hydro. I think that is why many think the RTV is under powered.
I like the way a belt drive system drives, except for the fact they don't compression brake. What is with that! They figured out how to do it with ATVs. I like the way the RTV holds you on a hill. I think if you lean towards "sporty", the RTV is not for you. If you lean to "utility" and you understand how to drive a hydro, then the RTV is. I would rather be pushing snow, bogged in mud or creeping up a hill with a heavy load with a hydro than slipping a belt. JMHO I would rather be running down dirt roads pleasure driving with a belt. If only one of the manufacturers would produce a belt driven diesel with compression breaking.
/ RTV in the mud #27
Two Guns, I completely agree with you about the Polaris. I did not elaborate on it earlier, but the Polaris does stay in the shop. I cannot believe how much trouble Polaris is having.
If you plan on running with the windshield installed, the Kubota's is the best.
The others tend to create a vacuum behind the windshield and just pull in more dust. If you are getting the enclosed model, then you should not have a problem at all.
milkman, ultimately it is up to you. Since dealerships won't offer a demo, maybe you could find some used side by sides for sale locally to test.
What does anyone know about these..
http://www.atvtruck.com/images/Tim's%20Truck.htm
/ RTV in the mud #29
All that and no video or pictures?? LOL
Happy Thanksgiving and God Bless you all
Goodgame :)
TWO GUNS said:
rutwad,
milkman said:
TWO GUNS,
Goodluck milkman~!
Tommy has some of the HPX.. :D
/ RTV in the mud #30
there ya'll go draggin da poor coonass into the arguement.lol need pictures?i still gotta get my boys to load them batteries.den i'ma gonna take an drive my three wheel drive hpx up a hill in 6 foot deep water with all dat in da bed. at da same time while watchin me some saints football on tv. and i'm gonna post a picture of it too. just as soon as i figure out how to do it all at one time.
/ RTV in the mud #31
Yea, just throw 'dem rocks at 'de coonass. He can take it yea !!!
Got no time to joke and play 'dem games. Gotta go to de back and
check on de Cochon de Lait >>>>
Now, da picture of dat waz in de computer yea !!!
But, that dem coonass huntin' only know 'bout dat !!!!
For 'em tit babies 'dat got to have 'em pics to understand what de thing is of " Cochon de Lait " ~~~ dat is dem Cajun Pig Roast, and not just a cajun cookin', it's a EVENT !!! Pic in de attachment below !!! There is you picture cam'cro-che !!!
/ RTV in the mud #32
I've learned over the years that you really have to take others' opinions with a grain of salt. So often a piece of equipment that rates highly is unsuitable for your intended use and conditions. So when I was looking at utility vehicles and thought the RTV was just the ticket, I had the foresight to negotiate with the dealer that I'd rent one for the weekend first, and if I liked it the rental cost would come off the purchase price.
Best move I ever made! Within a few minutes I had a moderate load of sand in the back and was cutting across my meadow...where it promptly cut huge trenches in the grass and nearly bogged down in the clay beneath. It handled my conditions so poorly that I quickly removed it from my wish list and went with a much lighter, more nimble ATV.
/ RTV in the mud #34
milkman said:
Well so far it's about even, owners like them, non owners say they're dogs, keep it coming, I'd like some more real experiences, I don't know if a dealer has a demo unit, or if any of them do for that matter.
I have owned a 2002 Kaw.3010 4X4 mule (Gasser)and now my 2006 kubota RTV 900.My kubota will go anyplace that my 2002 3010 mule would go,you just have to know how to drive it,with that said you have to use the proper gear in the kubota low,med,or high.The hydrostat drive system takes a little getting used to verses the mule.I can tell you this though,I would not trade my RTV 900 for anything else.coobie
/ RTV in the mud #35
TWO GUNS
When I google your cochon02300.gif it directs me to an illicit site??
I didn't understand what you were trying to say, so I searched google..
The image did help in the translation.
Sorry you had to eat swine instead of turkey. I am sure next year will be much better.
Katrina made it rough for Louisiana this year.
Goodluck in the future and Happy Holidays :)
/ RTV in the mud #36
hey skip i checked out the web site you posted but i don't see no xuv on it.i think you posted the wrong site they got some kinda other videos on there.them guys sure are friedly on there it says something about gay. and they all have smiles on thier faces.lol
/ RTV in the mud #38
Loll.
/ RTV in the mud #39
Skipholiday,
Maybe this site will help you understand. Sorry you got to the wrong website.
cochon de lait
What I was saying was, didn't have time to argue with you at the time, had to check out the cookin's ~~~
And as far as the Thankgiving thing, we also had turkey . Katrina didn't really effect us at all.
Don't be sorry about us having to eat swine, it don't have to be a holiday for the coonass' to have a cookin',( or a good time ) it's just a good 'old time get-together for some good folks. No fussin', No haggling, everybodys just friendly and enjoying life at it's best. Eating & drinking ~~ Cookin' the pig that way is a tradition in coonass country. Should try it sometime, the website tell you the story and how to cook it, weather it be a holiday, or just wanting to get some good people together.
/ RTV in the mud #40
sometimes we get together and fry up 4 or 5 turkeys at one time food is a way of life down here we sure won't starve . i never ate swine but them white egrets are pretty good when you put them on a pit.
TWO GUNS said:
Skipholiday,
cochon de lait
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A67148)
2015 FREIGHTLINER...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A64557)
2019 Mercedes-Benz...
2022 EZ-GO ELITE...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
