RTV 1100 Starting problem
/ RTV 1100 Starting problem #1
rockncreek
St Matthews, SC
JD 2355 and JD 5100M
I have a 2008 RTV 1100. Yesterday the engine would not turn over. and I got the tell tale click that in my limited experience indicated a low battery. I load tested the battery and it was bad, according to the load tester. Today I purchased a new battery with ample CCA. I installed the battery and when I turned the key to the start position all I got was the same click and with the other battery. I rechecked the terminals,cleaned and still the same results. I checked the connection to the starter and no issue. I called my dealer and the service dept was not much help other than to say bring the unit into the shop. I continued to try to start the RTV off and on all day and was more than a little frustrated. This evening I turned the key rapidly a few time and it turned over and started. Now I am wondering if it could be a switch issue. Anybody out there ever experienced this problem?
/ RTV 1100 Starting problem #2
Possibly the key switch or the solenoid on the starter. Next time it happens try bypassing the key. If it still happens then it is likely the starter solenoid.
Thank you! Will give that a try. Appreciate the feedback.
John Deere TX Gator (A60462)
John Deere TX...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2 new 8'' Pallet fork extensions (A61567)
2 new 8'' Pallet...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
John Deere 4044M (A60462)
John Deere 4044M...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
