RPM sender unit
/ RPM sender unit #1
Hayloft
Western Wash
3520HST
Hi there,
Anybody replaced the RPM sender ?
When first startup my 3520H sticks on really low RPM no matter what throttle is set at. After several minutes, like during warmup, the RPM starts reading normal.
Hmmmm I figured it's likely a sender unit starting to go.
2014 3520H model.
~Regards
/ RPM sender unit #2
The tachometer on the dashboard gets the signal from the alternator. It's a single wire that comes out the back.
You may want to check if the plug is fully seated and without corrosion.
/ RPM sender unit
Hey ptsg,
Thanks for your assist...I'll check that connection out !
Regards
/ RPM sender unit #4
Forgot to add on the other post but if that doesn't work, try wiggling the plugs behind the dashboard.
Might be necessary to pull some covers out though.
/ RPM sender unit
Yep
Got it & will do that.
Thanks
-Regards
60" HANG ON PALLET FORKS (A65056)
60" HANG ON PALLET...
2017 Bobcat T650 Compact Track Loader Skid Steer (A66734)
2017 Bobcat T650...
2018 FORD F-150 (A67714)
2018 FORD F-150...
1988 CAT 815B (A68134)
2007 INTERNATIONAL 9900I (A67714)
2007 INTERNATIONAL...
2000 Freightliner Classic XL T/A Sleeper Cab Truck Tractor (A66736)
2000 Freightliner...
